Dear community,
I have been searching in this forum and on the web to find an editing program for my needs.
I am recording in OBS to mkv and have around 4-5 different audiotracks to a recording.
My editor wants to have the recordings in mkv for quality-reasons.
Recently I want to cut out some parts, before sending them to my editor. They should be able to have access to the new version with all the audiotracks later on.
Therefore I need a program which can edit in mkv and can convert into mkv again.
As well as I would need the program to seperate the audiotracks (since I would need to delete some parts there).
Thanks for taking the time to read,
and greetings from Germany![]()
If your source is already mkv, you don't need to re-encode.
Cutting, extracting, omitting or adding tracks can be done with Avidemux or with clever FFmpeg-GUI.
Cutting is easier with Avidemux, extracting and muxing tracks is easier with clever FFmpeg-GUI. -
Maybe I'm misreading but I don't think mkv as such guarantees "quality" since it's a conatiner format. Perception of quality is initially determined by how well the elementary audio- and video-streams inside are.
I can imagine hard-cutting out parts leaving undesired transitions. First thought here you may need crossfading, perhaps both for audio and video. I can't tell if the suggested tools support this.
Should your editor be the person who will do this, you may want to deliver extra start- and end footage at the cutting points. -
Hello both, thanks so much for the reply.
I have been the past couple days sick. So my reply is a bit late.
I have been checking out Avidemux so far, as it looked at first glance appealing and seems so far promising. I am also going to check out the other one too. Thank you so much for the recommendations.
To the "quality", I am actually not so sure myself. But asked him right now, and am waiting for a response now.
This is a good point with the undesired transitions. I have different types of content. I need to look into crossfading. It is the first time to hear about it as a noobie.
I think it is an excellent idea though with the extra footage, so that problem could be somewhat solved.
[InpaintDelogo] Handle with multiple logos
By maudit in forum EditingReplies: 2Last Post: 5th Oct 2023, 18:18 -
How to add multiple subtitles into mkv as forced
By maverickluke in forum SubtitleReplies: 8Last Post: 25th Aug 2021, 03:22 -
Need to burn multiple MKV files to DVD
By danih952 in forum Authoring (DVD)Replies: 12Last Post: 20th Jun 2021, 13:14 -
How to list framerate of multiple mkv files.
By Perhana in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2021, 07:51 -
Remove dual audio to multiple mkv files
By hisaishi in forum EditingReplies: 9Last Post: 19th May 2019, 19:23
