Hello everyone, I’m having trouble removing these horizontal lines. I use Selur’s Hybrid, and I haven’t found anything effective against these lines..
Example:
B1_t00-00.04.05.472-00.04.15.768.mkv
Thanks!
Results 1 to 10 of 10
You have 2 kind of horizontal lines
1) interlace scanlines
2) rolling interference bars
1) you can remove by deinterlacing
2) avoid the interference. Is this a TV capture? -
I would divide up the scenes because other camera shots are not affected
The side effect of most "rolling bars"/flicker reduction filters is ghosting and softening of picture because they use some type of frame averaging .
I prefer to use weaker settings to reduce the ghosting, then follow up with some denoiser
This is Flicker Free + MCTD . Unfortunately, Flicker Free is a commercial plugin -
Defreq might work.
You might be able to adapt the work I did for removing moving exposure bars resulting from photographing a CRT with a movie camera:
Bad 1950s Kinescope - Hopeless?
This shows the before/after:
1955 NFL Football Noise Bars Before-After -
Thank you everyone, I will try the defreq and flicker free as mentioned..
MCTD =MCTemporalDenoise is a filter/script for Avisynth/Vapoursynth.
Flicker Free: https://digitalanarchy.com/demos/psd_win.html#d9 is plugin for different NLEsusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Davinci Resolve’s DeFlicker also works very well, thank you for giving me direction.
Looking for the best deinterlacing for near-horizontal lines
By Bwaak in forum Video ConversionReplies: 8Last Post: 2nd Feb 2024, 00:09 -
Horizontal/faint color lines through 8mm video - Handycam CCD-TR93
By krmtichell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 10th Sep 2023, 12:17 -
Horizontal Lines in entire video!
By Andreselos in forum RestorationReplies: 9Last Post: 22nd Jun 2023, 16:38 -
Horizontal Lines from VHS
By Pougan in forum Capturing and VCRReplies: 11Last Post: 25th Sep 2020, 01:16 -
VHS horizontal lines
By VHS_Hunter in forum RestorationReplies: 5Last Post: 27th Apr 2020, 00:45
