hello,
I'm about to do some re-dubbs of shows which run between 3-5 hours each.
Both audio formats of the original and the dub tracks
are in AAC 48000Hz stereo 161kbps which probably isn't a good working format. But when I convert theese files lossless
to uncompressed wav for example with a simple ffmpeg -acodec pcm_s32le -f WAV %1%.wav
They would be way too large to be recognised due to the filesize limit of the wav which is easily reached when using 24 or 32bit and having more than one channel and a longer runtime than 2 hours.
So would there be an alternative format I could convert this with ffmpeg to and then work with that in Davinci resolve and just export it as aac in the end.
It could be that I generate a loss when chosing aac as the final export format but I doubt that that would be audible I think its more important to process it and work with it lossless to preserve the quality.
thanks in advance for your help
Based on ffmpeg WAV muxer AVOptions:
I would add '-rf64 -1' option to your commandline. Also instead integer i would be on favor to use float. So it will be like:Code:-write_bext <boolean> E.......... Write BEXT chunk. (default false) -write_peak <int> E.......... Write Peak Envelope chunk. (from 0 to 2) (default off) off 0 E.......... Do not write peak chunk. on 1 E.......... Append peak chunk after wav data. only 2 E.......... Write only peak chunk, omit wav data. -rf64 <int> E.......... Use RF64 header rather than RIFF for large files. (from -1 to 1) (default never) auto -1 E.......... Write RF64 header if file grows large enough. always 1 E.......... Always write RF64 header regardless of file size. never 0 E.......... Never write RF64 header regardless of file size. -peak_block_size <int> E.......... Number of audio samples used to generate each peak frame. (from 0 to 65536) (default 256) -peak_format <int> E.......... The format of the peak envelope data (1: uint8, 2: uint16). (from 1 to 2) (default 2) -peak_ppv <int> E.......... Number of peak points per peak value (1 or 2). (from 1 to 2) (default 2)
Also there can be some issue present in ffmpeg - check https://superuser.com/questions/1822472/how-to-convert-a-wav-to-wave-audio-ieee-float-...tereo-44100-hzCode:ffmpeg -c:a pcm_f32le -f WAV -rf64 -1 %1.wav
Which format & bitrate is better to download for long-term collecting?
By gs684 in forum Video Streaming DownloadingReplies: 2Last Post: 21st Jun 2023, 02:16 -
Lossless Cut not working with Lumix S5 4K MOV files - any clues?
By Killayuz in forum EditingReplies: 2Last Post: 18th Jun 2021, 10:41 -
Lossy and Lossless compression: Is one format better than the other?
By Guernsey in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2021, 05:36 -
Check for lossless format
By kirkmc in forum AudioReplies: 34Last Post: 12th Feb 2021, 19:54 -
I would like to rip my movies, TV and anime series in a lossless format..
By the_importer007 in forum Video ConversionReplies: 25Last Post: 31st Jan 2020, 01:35
