i have a complex script that figures out what files it needs and downloads what it does not have with the goal of joining in sequence into a single video file. everything is in mp4 or webm container. it converts any mp4 to webm and even uploads the webm back to the file server. so the final join will have only webm files.
the critical issue is that this is all automated and not interactive.
this is also running on Ubuntu 20.04 LTS Linux (not 22.04) so ffmpeg is there if someone knows the magical incantations to make it do.
this script will be given multiple lists of videos to process overnight. each list identifies what is to be joined in the sequence as given in the list. if it gets 17 lists, it will create 17 join results if it has enough time. it automatically quits starting new joins at 6:00 AM. hopefully what got started at 5:59 AM will be done by 8:00 AM.
things i think i need:
1. program to fetch image size (horizontal and vertical) to know if it needs to be expanded to a larger size or if it is too large (that list will be skipped).
2. program to actually join two or more video files (converted and/or expanded as needed) into a single video file in the same webm container format.
Results 1 to 1 of 1
Joining Video Clips to Form Final Video?
By meeshu in forum EditingReplies: 9Last Post: 3rd Mar 2024, 07:49 -
Searching for automated Video editing
By fry3000fry in forum Newbie / General discussionsReplies: 10Last Post: 13th Nov 2022, 19:48 -
Avisynth: How joining two clips with overlay audio clip1 over clip2?
By marclli in forum EditingReplies: 0Last Post: 17th Oct 2021, 10:59 -
Avisynth slowdown when joining clips
By smike in forum EditingReplies: 3Last Post: 6th Jun 2021, 22:06 -
Audio out of sync when joining many clips together
By umbala in forum EditingReplies: 8Last Post: 7th Jul 2020, 13:46
