Hello I need help!
About my problem: For the first time it happens to me when an episode of a series that is put on a USB memory stick connected to my Samsung Smart TV Full HD 1920x1080p during the playback of the episode it jumps from one minute to the next and it happens a few times which is very annoying!
I use Clever FFmpeg-Gui to insert a subtitle to the multiplex but I also tried with MKVToolNix-Gui but it's the same situation!
I don't change anything from the original format, I just replace the subtitle!
General
Container......: Matroska
Duration.......: 42 min 26 s
Size...........: 2.86 GiB
Video
Codec..........: AVC High @ L4 8 bits
Type...........: Progressive
Resolution.....: 1920x1080
Bit rate.......: 9 009 kb/s
Frame rate.....: 23.976 (24000/1001) FPS
Audio
Format.........: E-AC-3
Codec..........: Dolby Digital Plus
Channels.......: 6 channels
Bit rate.......: 640 kb/s
Language.......: English
My system requirements:
Processor - AMD A10 6800k 4.1 Ghz
Video Card -AMD R9 270x 2GB
Memory - 8 GB RAM
Windows 10 Home
SSD 240 GB
HDD 1TB
Try playing the video without the subtitle.
Unfortunately, it is not possible without subtitles, otherwise I don't understand the story of the series very well! Anyway, thanks for the advice!
You don't need to understand the story to see if the skipping stops with no subtitle.
Copying 4k movies to 50 GB blanks using DVDFab-The copy stutters and jumps
By LloydS in forum Authoring (Blu-ray)Replies: 43Last Post: 26th Mar 2024, 06:35 -
MPC-BE Show OSD Time During Jumps?
By MythSpell in forum Software PlayingReplies: 0Last Post: 3rd Apr 2023, 17:38 -
Hybrid encoding a 42 minute dvd file to 34 minute
By johns0 in forum Video ConversionReplies: 7Last Post: 15th Jul 2021, 12:44 -
How to make keyframe jumps smaller?
By Felow in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2020, 00:09 -
3 mb per minute?
By Haopengyou in forum Video ConversionReplies: 4Last Post: 22nd Mar 2020, 09:14
