Results 1 to 30 of 36
  1. Hey guys, this is my first time to try to get video of this kind and the process is a bit too complicated for the first time. I have already spent few days, but I don't think I will be able to get in time, since it could be time limited...
    Would anyone be able to get this video in best quality in 1920x1080?
    If this is against the rules I really apologize in the most kindest manner and it is not my intention to offend somebody.
    Dec 2021
    england
    mpd showing only upto 720p
    --key 86e46cc9fda22f4d0b4650b33f11582d:87c464c8b4959c3199060177c52c3cf9
    N_m3u8DL-RE -M format=mkv --key 86e46cc9fda22f4d0b4650b33f11582d:87c464c8b4959c3199060177c52c3cf9 "https://lbcdn.6cloud.fr/resource/m6web/s/m6web/output/2/4/d/24d2f3adada225d7eaf6641a7769bebca18c7b09/static/13057756_e4cb2a762f6ac21c918dd60a019f4e34_web_dash_upTo720p_720p_vbr_cae_drm_software.mpd?expiration=1710110384&scheme=https&groups%5B0%5D=m6web&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpYXQiOjE3MTAwNzQzODMsIm5iZiI6MTcxMDA3NDM4MywiZXhwIjoxNzEwMTEwMzg0LCJyX2hhc2giOiJkMTI5ZTY3NzBhODNhNjBhYjBlMmY0ZmY3MWZkNWM3YTM3NDFlZDk5In0.T-2zivhf8DU-mnLjCOwPcT0VjOtKWvLWhLYk4DjL6TA" --save-name video
  3. Yes only 720p....
  4. 1080p only available with 6play max (paid subscription)
  5. I have paid for subscription but I am still experiencing problem to get the specific video in 1080. As mention this is my first time to do this...
    Thank you very much for your kindness and for your time as well.
  6. Thanks Pouki2 for information
    Your file in 1080p via 6play Max
    https://www.transfernow.net/dl/20240310OwfCZNSJ
  7. Dear all, thank you from the bottom of my heart for your extreme kindness and your valuable time.
    This really means a lot, thanks for being so cool.
    Dear @cedric8528 thank you very much for your effort and amazing help.
    I only have a question regarding the sound, since you guys are such experts.
    Is the 96.0 kb/s the best audio quality possible on this specific video and on 6play in general?
  8. Thanks to pouki2 for providing me with the info that 6play highest audio quality is always 96.0 kb/s
    Thanks once again everyone.
  9. Hi,
    I don't know how you do it but I can't get my 6play video with N_m3u8DL-RE.
    Can you help me please ?
    https://www.6play.fr/le-1245-p_1056/le-1245-du-28-03-2024-c_13061129
    In 1080p if possible. Thank you so much
  10. Code:
    N_m3u8DL-RE "https://th2-edge-01.cdn.bedrock.tech/m6web/output/5/7/5/575ab7a0c988da2a16546c5ba2dad92cf1d7b0dd/static/13061129_3414220f553f16c56381ca912bcd69fc_web_dash_upTo720p_720p_vbr_cae_drm_software.mpd?st=ZZLXcfFqKrAwDXoZSbYUJA&e=1711736685" --key cdcd14fcc6dc8caae31e6799207b140a:d167db55b9ac80383285625b189d23b9 -M format=mkv
    720p
    your file
    https://www.transfernow.net/dl/20240329QSTpIOT0
  11. Originally Posted by cedric8528 View Post
    720p
    your file
    You helped me a lot with my personal archive
    Thxxxxx !!!!!
  12. Originally Posted by pouki2 View Post
    Thank you very much indeed!
    I know how to download and decrypt with TF1 but 6PLAY unfortunately fails after failures :'(
    I would really like to know how to do that for my archives!!
    Thank you, thank you and thank you!!!
  13. Pouki2 have 6Playmax account so thank you for 1080p ��
    Like TF1 Drm encryption video you need PSSH and Licence Url.....and for 6play you need also to put in headers "x-dt-auth-token: ".
    You will find this in Console Developper (F12)
    [Attachment 78003 - Click to enlarge]
    Now with https://cdrm-project.com/
    [Attachment 78002 - Click to enlarge]
  14. Originally Posted by cedric8528 View Post
    Thx !!!
    For OQEE.TV, do you also have a solution?
    Sorry for going off topic.
    And for NETFLIX I am looking to download the film CROSSROADS in French audio version in its restored version in 1080p.
    Arrived in January on Netflix I think... and therefore with the new DRM
    thank you for everything
  15. Member aqzs's Avatar
    Mar 2024
    Paris
    Im switching from orange to free so i'll soon or later acces to oqee.tv and experiment with it ! If you have more informations about this service feel free to pm me !
  16. I have tried avec oqee.tv but I can't.
    It dont't work.
    I think that a expire of token.
  17. Member aqzs's Avatar
    Mar 2024
    Paris
    It dont't work.
    You can send me a private message if you want.
  18. Originally Posted by aqzs View Post
    Hi,
    The Oqee identifiers are the identifiers of the main account of the Freebox subscription.
    It is therefore impossible to share these identifiers.
    Do you have access? You succeeded ?
  19. Member aqzs's Avatar
    Mar 2024
    Paris
    Hi,
    I'll soon have acces !!
  20. I think that the problem is that token expire quickly and it is obsolete
    May 2024
    Morocco
    Good evening Cédric,
    I followed all your steps and I think I did everything correctly except for finding the PSSH. I managed to download the MPD file using an extension, and now I have a file containing exactly 24 <cencssh>pssh</cencssh>. The site "https://cdrm-project.com/" gives me the error: "ERROR 'str' object has no attribute 'items'".
    Could you please guide me? Thank you very much.
  22. picabuuu juan's Avatar
    May 2024
    Mars
    @moby
    if you have the correct pssh , then the problem is in the header . i think the token is expire .
    Logout and login again , make sure that the lic url is [type] json/js .
  23. Member
    May 2024
    Morocco
    Originally Posted by juan View Post
    @moby
    Hello,
    For me, everything is correct. The license URL is correct, and the tokens are too.
    I believe the problem lies with the PSSH. I have a file with many PSSH entries, and I don't know which one to use.
  24. PSSH looks correct at first glance. "Headers" otoh takes Key-Value pairs; the JWT definitely needs the corresponding field value (the "Key"). That might explain the error you got.
  25. picabuuu juan's Avatar
    May 2024
    Mars
    edit your header .
    x-dt-auth-token: eyJhbGci..............................
  26. Member
    May 2024
    Morocco
    edit your header .
    I modified it. I refreshed the page several times to get the latest tokens, but nothing works.
  27. Member
    May 2024
    Morocco
    Sorry, but I'm not sure I understand. To be honest, I am an amateur in these things. I just need this video found on this website: "https://www.6play.fr/mocro-maffia-p_19275/s3-e1-zakaria-c_12952094" and some explanations on how to obtain this video file.
    And I've been stuck for 2 weeks...
  28. Member aqzs's Avatar
    Mar 2024
    Paris
    --key 53524f37dcb7bd69617217c7aed4c351:889b252c8bf064a4b906898c3790d371
    HTML Code:
    N_m3u8DL-RE --key 53524f37dcb7bd69617217c7aed4c351:889b252c8bf064a4b906898c3790d371 'https://th2-edge-01.cdn.bedrock.tech/m6web/output/b/8/9/b895e14f17541177df2950bc88926780ab83553f/static/12952094_4456f0b24920c673dee87e0f80dc3b9b_web_dash_upTo1080p_1080p_drm_software.mpd?st=oloEGuX3x4wPAMjCf8k0zQ&e=1716766698' -M format=mkv --save-name Mocro.Mafia.S03E01
    (you can send a private message so we can talk in french if you want)
