Hi there,
since i tried to install freevine, now my script doesn't work anymore ?!
[Attachment 77537 - Click to enlarge]
how can I go back to the situation before when everything was working... please ?
Simply uninstalling pywidevine should do it:
Although, I'd highly recommend learning how to use python's virtual environments. Having everything installed globally is just asking for problems.Code:pip uninstall pywidevine
Waveform generated from previous editing session doesn't appear. Mst regen
By FadeToPurple in forum SubtitleReplies: 0Last Post: 6th Mar 2024, 18:40 -
QTGMC Stutter and Replaying Previous Frames
By nikkmann in forum Video ConversionReplies: 81Last Post: 7th Aug 2022, 23:31 -
copying parts from the previous frame to the current one?
By romeo in forum RestorationReplies: 13Last Post: 30th May 2021, 13:57 -
How do you check the profile and previous posts of a software reviewer?
By gll99 in forum FeedbackReplies: 3Last Post: 9th Dec 2020, 11:42 -
Invalid title time after jumping back to previous title
By Bencuri in forum Authoring (DVD)Replies: 3Last Post: 29th Oct 2019, 03:46
