  1. I would like some help regarding my VX9000 DV (not mini DV) camera which I have owned from new with absolutely no faults and so far no repairs. It now has a problem playing a tape. After appearing to load normally it starts playing but very soon after slows down and stops, it will however play the cleaning tape.
    Any advice much appreciated
    https://youtu.be/djveVF6iDkM
    Jan 2016
    You have a problem with the tape, Either sticky shed syndrome or the reels are mechanically dragging, Get the tape fixed by baking if SSS or or swapping the shells if mechanical problem.
  3. I have several tapes and it does the same thing with all of them. Except the Sony cleaning tape.
    The terms "sticky shed syndrome", "baking" and "shells" need further research on my part.
