i have an old fs 3D disc and need to merge all files so they can be added to Virtualdub
then a script to turn them into S/s half hight to use on a 3D digital TV set
how to add the script into virtualdub
I know these are real old and I was hoping someone might still have the knowledge to perform this task
Results 1 to 9 of 9
thanks first i need to know how to strip a fs 3D DVD with files to make it one file length
the program I have puts in more interlace lines -
Not sure what you mean by "more interlace lines".
If you are ripping the disc properly, it should be exactly what was on the disc. Many folks use an app that in actuality is ripping + re-encoding. You do NOT want to do that.
Since FS 3D dvd discs are an older technology, and therefore are likely to be older titles, this is a scenario where it still makes sense to use something like DVD Decrypter, as that can be set to rip a title as only a single file, IIRC. It's been a while now, so you'll have to look up steps, but back in the day, I used to rip & demux to single mpg2 video file, find my intended audio stream and rip & demux to single audio file (usually ac3), and then use a separate app (TMPEGenc, Manzanita, Imago, etc) to mux them together into a single, contiguous, straight MPG file.
Scott -
OK i have made it into one file now I need to convert it to mp4
the newer converters messes up the FS when they convert
any suggestions would be appreciated -
I'm not going to write the script for you, as there are tons of examples here and elsewhere, and it is much better to write it yourself so you can understand it better.
The gist of it is like this (not using proper notation here, this is just a functional flow):Input video = /file/, using proper input format dll/filter
This resultant layout is incorporated within vdub or piped into another app, which will do the (re-) encoding.
Input audio is similar
Merge audio with video
Separate fields into even & odd
Resize each to proper size for their portion of the frame
Combine even & odd onto single frame in proper layout
As has been mentioned before, it's a very good idea to build the script using avspmod so you can get a real-time preview, building it line by line and seeing what changes. Note that if it isn't made explicit in variable names, what you are seeing and what it is working on is the LAST (most recent previous) thing done. Also, if you are unsure about what you're doing, you can temporarily drop in a line that shows video info metadata as an onscreen overlay, just don't forget to remove/comment it out by the end.
Avisynth, once installed, is a latent resident app that goes into action only when called by an app/process that supports Avisynth and recognizes a properly formed script. You never manually run it itself in the foreground. In that way, it is a lot like Python, Basic, or other interpreted programming languages.
ScottLast edited by Cornucopia; 16th Mar 2024 at 20:01.
realy appreciate that info but its a one only disc to do so a don't really need to know that , all I would need to know
is how to put a script in to avisynth and run it
as I said I have this DVD fs disc and silmpy want a side by side half frame version
I'm not looking to complicate the situation just looking fo someone that can help me
require info on FS 3D convertion please
By xenon1 in forum Video ConversionReplies: 0Last Post: 7th Mar 2024, 00:07 -
Why does Handbreak need TS info file?
By tom z in forum Video ConversionReplies: 9Last Post: 29th Nov 2021, 05:48 -
Any *recent* info on Skystream ?
By Seeker47 in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Apr 2021, 03:51 -
info tsMuxeR
By Ripem in forum Newbie / General discussionsReplies: 4Last Post: 19th Apr 2020, 12:28 -
DVD video convertion
By escarlate in forum Video ConversionReplies: 10Last Post: 18th Jun 2019, 12:46
