Results 61 to 76 of 76
I remembered about your old comment when I saw this post again. Doubt you're gonna see this since you're not that active recently but I made a guide here. No idea if it's what you expected but I had fun writing it.
No problem. If you don't manage to get one on your own, there's also a sticky post where you can get emulated ones thanks to @karoolus. To be honest, you shouldn't give up learning how to get one yourself, but you have alternatives.--[----->+<]>.++++++++++++.---.--------.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Ozivine is working fine.
I was trying to download a video from Eurovision using Widefrog. I get the following error. The video is definitely there. Am I doing something wrong?
Received login request response: {'refresh_token': 'eyJraWQiOiIyODAwMTQiLCJhbGciOiJIUzI1NiIsInR5cCI6I kpXVCJ9.eyJ2ZXIiOiIxLjAiLCJ0ZW5hbnRJZCI6Im5hZ3JhIi wiYWNjb3VudFByb2ZpbGVJZCI6IkRFRkFVTFQiLCJleHAiOjE3 Mzc2Mzc1NzMsImRldmljZUlkIjoiNjZhNGYwYzVjYzUzNzE3Nm YzYTQ3MWEyIiwiZml4ZWRfZXhwIjoxNzUzNjIxNTczLCJhY2Nv dW50SWQiOiI2Njc0MWYzOTIyYzVlYjU4ZDYyNzBmY2EiLCJzZX NzaW9uQ29udHJvbCI6eyJtYXhTZXNzaW9ucyI6MTAwMDAwMDAw MCwic2Vzc2lvbkNvbnRyb2xFbmFibGVkIjpmYWxzZX0sInR5cC I6IlJlZnJlc2hBdXRoTiJ9.Nz1NeUkf-5Kf2XIMVrurKm8TwKRcrXrB03AA9Fwem30', 'access_token': 'eyJraWQiOiIyODAwMTQiLCJhbGciOiJIUzI1NiIsInR5cCI6I kpXVCJ9.eyJ2ZXIiOiIxLjAiLCJ0ZW5hbnRJZCI6Im5hZ3JhIi wiZ2VvQmxvY2tFeGVtcHQiOmZhbHNlLCJiaWxsaW5nQ291bnRy eUNvZGUiOiJBVSIsImRldmljZUlkIjoiNjZhNGYwYzVjYzUzNz E3NmYzYTQ3MWEyIiwiZmlsdGVyaW5nSW5mb3JtYXRpb24iOnsi cG9zdGFsLWNvZGUiOiIyNTYwIiwiY291bnRyeSI6ImF1c3RyYW xpYSIsImNvdW50cnktY29kZSI6IkFVIiwicmVnaW9uLWZ1bGwt bmFtZSI6Im5ldyBzb3V0aCB3YWxlcyIsIm1ldHJvLWNvZGUiOi IzNjEyMyIsIm51bWVyaWMtY291bnRyeS1jb2RlIjoiMzYiLCJt ZXRyby1uYW1lIjoic3lkbmV5IC0gb3V0ZXIgc291dGggd2VzdC IsImNpdHktbmFtZSI6ImxldW1lYWgifSwiYmxvY2tpbmdJbmZv cm1hdGlvbiI6e30sImFjY291bnRQcm9maWxlSWQiOiJERUZBVU xUIiwiYWNjb3VudElkIjoiNjY3NDFmMzkyMmM1ZWI1OGQ2Mjcw ZmNhIiwiY291bnRyeUNvZGUiOiJBVSIsImV4cCI6MTcyMjE3MT k3MywiZml4ZWRfZXhwIjoxNzUzNjIxNTczLCJvbk5ldHdvcmsi OnRydWUsInNlc3Npb25Db250cm9sIjp7Im1heFNlc3Npb25zIj oxMDAwMDAwMDAwLCJzZXNzaW9uQ29udHJvbEVuYWJsZWQiOmZh bHNlfSwidHlwIjoiRGV2QXV0aE4ifQ.TfSqZ9S_rLMBWUV7f25 g_cJolJ2TNXjCYO2mc_HHrTQ', 'client_id': '66a4f0c5cc537176f3a471a2', 'fixed_refresh_expires_in': 31536000, 'accountId': '66741f3922c5eb58d6270fca', 'refresh_expires_in': 15552000, 'expires_in': 86400, 'token_type': 'bearer'}
[INFO] Current progress: [1/1]
[INFO] Starting the collections extraction stage.
[INFO] Starting the media data extraction stage.
[USER_ERROR] Failed to download: https://eurovisionsport.com/mediacard/EVS_240721_F_20240718EABanskaBystrica_58. Reason: The content isn't available. Solution: Do not attempt to download it.
[INFO] Finished generating the download commands.
[WARNING] No download commands have been generated. -
No problem. Don't forget, the tool is better used in mass downloading. You can get entire tournaments from that site. Just read the post and check the section relevant to your site for all possible use cases. It's all explained there.
I was planning to mass download the world u20 athletics championships 2024. It was advertised to be livestreamed on Eurovision(still is)but it seems it will be livestreamed only on the world athletics website. They did that with the world indoor championships 2024 as well, but never livestreamed anything.
https://worldathletics.org/competitions/world-athletics-u20-championships/lima24/where...countryCode=AU
Is there a way to download from the world athletics website? I checked this site and there is nothing on it. Perhaps you might wanna consider adding world athletics to the list of download platforms supported in widefrog.
World Athletics uses brightcove for streaming their events. Earlier(when there was no need to login)you could simply take the Account ID and the Video ID, put in a URL meant to download Brightcove videos, and download the video using Clipgrab. With the introduction of logging in, it does not work anymore.
[Attachment 81818 - Click to enlarge]Last edited by EV Downloads; 28th Aug 2024 at 05:38.
That's unfortunate then. If the site uses DRM, you should check one of the key extractors from the sticky threads. They don't do batch downloading but they're helpful for individual videos
Here is a simple script to get download commands for this website :
HTML Code:import requests from slugify import slugify import re import json def getcmd(videoId): policyKey = "BCpkADawqM3NbFGPYs_dUwMMZwDDjhGseVlQkYZfkZGD8DZ2S45alnFziG1LN4inz1jzvgWikxdkgI8QE3Php2CBm3GKue_qJcmkNI2qoQxtXTGsW-jatK8d57GfvpmxB8xkFhqtcWHE3o6JClFVBi_t7jHAu2W3PaHGVONA4oIIX_rmgTLA1jsDU3VqYbr9u0ylNN3B6o8spjZdITCpHZSFPXbPfuonCu6BNCNKg-CS2NNc8C31i2bViFWvZY7vx145Yrs0bVLKELiIUfoLr5Vpax2XMWTMReDtsAuB2qkzzihP0SIasGVresmpKL9ko2HZlXhfir0TdFNg" headers = {'accept': f'application/json;pk={policyKey}','origin': 'https://worldathletics.org',} response = requests.get(f'https://edge.api.brightcove.com/playback/v1/accounts/{ACCOUNTID}/videos/{videoId}', headers=headers).json() for source in response['sources']: if source.get('type'): if source['type'] == "application/dash+xml": if 'https' in source['src']: mpd_url = source['src'] name = slugify(response['name'], separator='.', lowercase=False) print(f"""N_m3u8DL-RE "{mpd_url}" --save-name "{name}" -sv best -sa all -ss all -mt -M format=mkv --log-level OFF""") def getvideoId(url): response = requests.get(url) content = response.text pattern = r'<script id="__NEXT_DATA__" type="application/json">(.*?)</script>' match = re.search(pattern, content) if match: data = json.loads(match.group(1)) videoId = data['props']['pageProps']['video']['videoId'] print('videoId: ', videoId) getcmd(videoId) else: print("Pattern not found") ACCOUNTID = TRUNCATED # 13 numbers that can be found right after : 'https://edge.api.brightcove.com/playback/v1/accounts/.....' # videourl = 'https://worldathletics.org/videos/playlist/latest-videos/66ce940cf04f96632de47276' videourl = input("Enter the video url: ") getvideoId(videourl)(This script seems to bypass georestiction)Code:Enter the video url: https://worldathletics.org/videos/playlist/latest-videos/66ce2b2ab63f43bd3057af52 videoId: 6361114623112 N_m3u8DL-RE "https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/clear/6415670005001/0ee98412-33cb-4227-a967-026c5c760681/6s/manifest.mpd?fastly_token=NjZjZjAzZTFfNTljNWM3OGMwZmIwYzVkMjA3Mjc5MmExNDU3ODA5MjBmZGJmMzg3YWViMjNkNTEyNjUxNTgxNzI0YmZhNmJmNA%3D%3D" --save-name "World.Athletics.U20.Championships.Lima.24.Day.1.Afternoon.Session.Replay" -sv best -sa all -ss all -mt -M format=mkv --log-level OFF
For non-DRM, yt-dlp is good. You should check their supported sites, they have a lot
https://github.com/yt-dlp/yt-dlp/blob/master/supportedsites.md--[----->+<]>.++++++++++++.---.--------.
Ha! Love you pepe <3
No need for any more doubt. I saw it. A month or so passed, but I saw it!
Now, let me find another month or so, to actually read it like one is supposed to!
Too bad the school year started and I'm kinda busy now, but I'll give my best to give it a full proper read. -
Help obtaining keys
By DenialOfJustice in forum Video Streaming DownloadingReplies: 8Last Post: 28th Jan 2025, 02:34 -
need decryption keys for this
By swappyison in forum Video Streaming DownloadingReplies: 6Last Post: 15th Jul 2024, 15:30 -
Decryption fails with keys
By vwolf in forum Video Streaming DownloadingReplies: 15Last Post: 15th Jul 2024, 15:27 -
not able to find a way for obtaining keys..
By killua in forum Video Streaming DownloadingReplies: 4Last Post: 28th Jul 2023, 04:21 -
Decryption Keys from oneplus.ch
By 3limin4tor in forum Video Streaming DownloadingReplies: 3Last Post: 8th Jun 2023, 01:20
