Dear all - my first post, I have been reading and educating myself but not having luck obtaining decryption keys for a Eurovision Sport video. I tried obtaining it using a couple of web-based keys tools but am receiving errors.
If anyone can help with this I'd appreciate it (trying to learn the process better so I don't need to ask, please bear with me).
Thank you.
Video link:
Code:https://eurovisionsport.com/mediacard/EVS_OBE_240308_M_24-10262
MPD:
Code:https://evs-ltcu-dash-secure2.akamaized.net/out/v1/fd9c31e9005744fd8855048e22123129/a44b11c8e63146eda52561238d4f2551/547a9906db0d477e9db4ba67ce28f69c/manifest.mpd
License:
Code:https://evsp4wab.anycast.nagra.com/EVSP4WAB/wvls/contentlicenseservice/v1/licenses
KID (from MPD):
Code:12202D3D-DFD1-476B-A788-2065EFBA1F51
PSSH (I think! generated using https://emarsden.github.io/pssh-box-wasm/generate/ from the KID, did not change any of the default settings):
Code:AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEBIgLT3f0Udrp4ggZe+6H1E=
Headers:
Code:Connection: keep-alive Content-Length: 3946 content-type: application/octet-stream Host: evsp4wab.anycast.nagra.com nv-authorizations: eyJraWQiOiIyODAwMTQiLCJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ2ZXIiOiIxLjAiLCJleHAiOjE3MDk5MTIzODEsImNvbnRlbnRSaWdodHMiOlt7ImR1cmF0aW9uIjo4NjQwMCwic2Vzc2lvbkNvbnRyb2wiOnsiZ3JvdXBzIjpbeyJtYXhTZXNzaW9ucyI6MTAwMDAwMDAwMCwiZ3JvdXBJZCI6IjY1ZTczYWUwMTIzODllNjIwOTQ1YjMzNSJ9XSwic2Vzc2lvbkNvbnRyb2xFbmFibGVkIjpmYWxzZSwibWF4U2Vzc2lvbnMiOjEwMDAwMDAwMDB9LCJzdG9yYWJsZSI6ZmFsc2UsImNvbnRlbnRJZCI6IjIwMjNfRVZTX0lCVV8yX0RBU0giLCJzdGFydCI6IjIwMjQtMDMtMDhUMTU6MzQ6NDFaIiwiZW5kIjoiMjAyNC0wMy0wOVQxNTozNDo0MVoifV0sImp0aSI6IjQwNjUxMzY1LThmYzMtNGNjMC04ODNjLWRlM2E0OTA1ZGEwYSIsImRldmljZSI6eyJ3YXRlcm1hcmtpbmciOmZhbHNlLCJhY2NvdW50SWQiOiI2NWU3M2FlMDEyMzg5ZTYyMDk0NWIzMzUifSwidHlwIjoiQ29udGVudEF1dGhaIn0.UGk0Zd3xXNa3hSstQKMA_ETvLozvfFlnftP5-I7oEXY Origin: https://eurovisionsport.com Referer: https://eurovisionsport.com/ User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36
Results 1 to 30 of 79
1. Your PSSH is incorrect. You can find the correct one inside the MPD file or with Eme logger.
2. You need to block the license request URL, reload the page, the video won't play, but the license url will show up in red and in headers you will find the nv-authorizations one. That's the only header you need.
You can't get keys because the nv-authorizations header is a one time use.
By doing what I explained, makes the header unused, and you can use it in a script to get the keys. -
I think someone could automate this, their API is kinda neat from a first glance.
Edit: This should be the key @OP
I'm gonna try and see if I can automate the login as well.Code:12202d3ddfd1476ba7882065efba1f51:5cc933a718d2ebc7477634d693879be2
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Excellent! Thanks both, that worked. I didn't know the nv-authorizations was a single-use header. Appreciate it.
Here is the final script if you wanna use it for other videos. You need a CDM in WVD format and you also need to fill in your email and password:
Output:Code:import json import re import requests from pywidevine.cdm import Cdm from pywidevine.device import Device from pywidevine.pssh import PSSH EMAIL = "YOUR_EMAIL" PASSWORD = "YOUR_PASSWORD" LICENSE_URL = "https://evsp4wab.anycast.nagra.com/EVSP4WAB/wvls/contentlicenseservice/v1/licenses" WVD_FILE = "./device_wvd_file.wvd" LOGIN_API = "https://api.evsports.opentv.com/ias/v2/token?grant_type=password&username={email}&password={password}" EDITORIALS_API = 'https://api.evsports.opentv.com/metadata/delivery/GLOBAL/vod/editorials?filter=%7B%22editorial.id%22:%7B%22$in%22:%20%5B%22{video_id}%22%5D%7D,%22locale%22:%22en_US%22,%22isValid%22:true,%22isVisible%22:true%7D&limit=9999&sort=%5B%5B%22Title%22,%201%5D%5D' CONTENT_API = 'https://api.evsports.opentv.com/ias/v2/content_token' def get_token(): return json.loads(requests.post( LOGIN_API.format(email=EMAIL, password=PASSWORD), json={}, headers={ 'host': 'api.evsports.opentv.com', 'tenantid': 'nagra' } ).content.decode())["access_token"] ACCOUNT_TOKEN = get_token() def get_video_data(source_url): video_id = re.search(r"/mediacard/([^/]+)/?", source_url).group(1) response = json.loads(requests.get(EDITORIALS_API.format(video_id=video_id), headers={ 'Authorization': 'Bearer {token}'.format(token=ACCOUNT_TOKEN), }).content.decode()) video_data = [] for e in response["editorials"]: if e["id"] != video_id: continue for t in e["technicals"]: av = t["media"]["AV_PlaylistName"] video_data += [(av["uri"], av["drmId"])] manifest, drm_id = [v for v in video_data if ".mpd" in v[0]][0] response = requests.get(manifest).content.decode() try: pssh_value = re.search(r'<cenc:pssh\b[^>]*>(.*?)</cenc:pssh>', response).group(1) except: return manifest, None, None response = json.loads(requests.post( CONTENT_API, params={ 'content_id': drm_id, 'type': 'device', }, headers={ 'Nv-Tenant-Id': 'nagra', 'Authorization': 'Bearer {token}'.format(token=ACCOUNT_TOKEN) } ).content.decode()) content_token = response["content_token"] return manifest, pssh_value, content_token def get_keys(pssh_value, content_token): if pssh_value is None or content_token is None: return [] pssh = PSSH(pssh_value) device = Device.load(WVD_FILE) cdm = Cdm.from_device(device) session_id = cdm.open() challenge = cdm.get_license_challenge(session_id, pssh) licence = requests.post(LICENSE_URL, data=challenge, headers={ 'nv-authorizations': content_token }) licence.raise_for_status() cdm.parse_license(session_id, licence.content) keys = [] for key in cdm.get_keys(session_id): if "CONTENT" in key.type: keys += [f"{key.kid.hex}:{key.key.hex()}"] cdm.close(session_id) return keys def get_download_command(source_url): manifest, pssh_value, content_token = get_video_data(source_url) keys = get_keys(pssh_value, content_token) if len(keys) == 0: return f"N_m3u8DL-RE.exe {manifest} -M format=mkv" return f"N_m3u8DL-RE.exe {manifest} {' '.join([f'--key {k}' for k in keys])} -M format=mkv" print(get_download_command("https://eurovisionsport.com/mediacard/EVS_OBE_240308_M_24-10262")) print(get_download_command("https://eurovisionsport.com/mediacard/EVS_XEJ_240217_MX_24-3261A")) print(get_download_command("https://eurovisionsport.com/mediacard/EVS_2023-10-08_FEED_FIG_1_DEF_F_TIME_12_50_ID_23-7614")) print(get_download_command("https://eurovisionsport.com/mediacard/EVS_240204_EDD_25128_"))
I only tested it for 4 videos and seems to be working fine. Fun fact, they send the password in plaintext through the use of query parameters. Nice security there. Also, I don't know if I'm the only one but I can't directly access a video link unless I access it from the category page. Weird.Code:N_m3u8DL-RE.exe https://evs-ltcu-dash-secure2.akamaized.net/out/v1/fd9c31e9005744fd8855048e22123129/a44b11c8e63146eda52561238d4f2551/547a9906db0d477e9db4ba67ce28f69c/manifest.mpd --key 12202d3ddfd1476ba7882065efba1f51:5cc933a718d2ebc7477634d693879be2 -M format=mkv N_m3u8DL-RE.exe https://d9e3795b4d13e5700fc6b7b92345cee0.egress.mediapackage-vod.eu-west-1.amazonaws.com/out/v1/740de75e27c64493bbbe8e8d25d6f42c/a44b11c8e63146eda52561238d4f2551/547a9906db0d477e9db4ba67ce28f69c/manifest.mpd --key ded50c78cc0d47e19cf944e5dbc56cc6:e1075fba590e616ddde64edb708466fa -M format=mkv N_m3u8DL-RE.exe https://d9e3795b4d13e5700fc6b7b92345cee0.egress.mediapackage-vod.eu-west-1.amazonaws.com/out/v1/4355df2ac4a442259a7079d110cfdcc4/a44b11c8e63146eda52561238d4f2551/547a9906db0d477e9db4ba67ce28f69c/manifest.mpd --key b0bfeb538deb410885a0e38b66c0f77d:044115b5331a5dfd618ef22b14e3883f -M format=mkv N_m3u8DL-RE.exe https://evs-vod-secure2.akamaized.net/MediaConvert-CDN/E1_S01R01_JEDDAH_26MIN_HIGHLIGHTS_7fd52aa5-9834-46b0-b1d3-e685cfd886ab-proxy_Trim/E1_S01R01_JEDDAH_26MIN_HIGHLIGHTS_7fd52aa5-9834-46b0-b1d3-e685cfd886ab-proxy.mpd -M format=mkv
Edit: I won't maintain this script since their site is bugged as hell when it comes to manifests. But I'll leave the script in case someone wants to improve it.
Edit2: Fixed it somehow by ignoring the failed fragments. The service has been added to widefrog so it won't be maintained here.Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 22nd May 2024 at 07:17.
Excellent job Pepe!
Perhaps in the future, when you find the time and willingness, try to write a detailed guide on how you go about automating stuff
It's Python knowledge and looking at the network tab mostly, but still. -
Thanks @vegeta
If you're talking specifically about the scripts used to download DRM content, they're basically glorified data scrapers on top of a pywidevine script. Everyone knows the basics of pywidevine scripts and what they need:
- license
- pssh
- headers
- mpd (if you want to download stuff)
So how do you get those? You build a data scraper that gets all those components. There isn't one magic trick that solves everything but rather a set of steps that you hope may help you. As a matter of fact, I already described what you wish as a guide here
https://forum.videohelp.com/threads/413705-ffmpeg-other-stuff!-[be-gentle]#post2726989
I guess if you want it more detailed than that, I would have to make a post where I apply this methodology on a specific website and describe the results step by step. But I doubt people are interested in this since it's just programming and most people come to this forum to download stuff. People who can write scripts can simply follow the guideline I posted (it's not something groundbreaking though ¯\_(ツ)_/¯ ).
Edit: I made a guide here
https://forum.videohelp.com/threads/415366-the-slacker-s-guide-to-mass-downloading-(mo...on#post2743977Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 23rd Jul 2024 at 03:47.
Hi,
When testing your script, out of curiosity, there is an error with this video
Sports -> Electric Racing -> Highlights - E1 Jeddah GP
Code:https://eurovisionsport.com/mediacard/EVS_240204_EDD_25128_
I'm interested to learn more about how did you find the API URL and login/password parameters?Code:line 45, in get_video_data manifest, drm_id = [v for v in video_data if "manifest.mpd" in v[0]][0] IndexError: list index out of range -
Greetings @ice!
Wow. Nice find. I expected all their videos to have DRM. Apparently not. If you try to download manually that one, you won't even find a pssh from the eme logger or in the special mpd named proxy.mpd (not manifest.mpd). So even if you replace "manifest.mpd" with ".mpd" to be more general in the script, it still fails because there is no PSSH. I checked N_m3u8 on that proxy.mpd and it downloads directly with no encryption.
I am lazy so I won't even modify the script for this case. If someone wants to modify it or incorporate it into other tools etc., feel free to do it, I don't mind one bit.
Well, that request was needed to get the token. The token was one of those special components that aren't even related to the source page. So you need to think outside the box for a bit and investigate other related pages from the website itself. So I thought, ok, there are 2 types of tokens: content token and bearer token. You already got the content token from another request and that is tied to the video page itself.
So then the other bearer token is definitely tied to the account itself (maybe?). I then tested the login request to investigate it a bit but of course, it ain't easy. Most websites simply redirect you to another page, and I wanna see the request clearly. So out of laziness to fix this issue in the browser, I hooked up an interceptor (postman). You can see it in action here:
https://forum.videohelp.com/threads/413561-How-to-download-video-from-this-website-i-c...ng#post2725571
Then you capture the login requests and surprise, surprise. The bearer token I captured manually from the previous video page requests looks like the one from the login request. And the problem was solved. There are other tools that can be used instead of postman. I am just mentioning this one to make it more known
You're welcome. I modified the script to handle non-DRM videos as well. I also used your found video as an example. I guess you could skip entirely the cdm part if you call the API provided by cdrm-project (https://cdrm-project.com/api) since the eurovision license call doesn't even require a custom script. But I don't like calling external APIs when you can do the job yourself so I'm gonna leave it like that (less critical points where stuff could break unexpectedly).
I don't think this is a skill issue. Rather it is about experience. Skill becomes a problem when you start writing the Python code. But if you already know basic Python, it all comes down to experience when you inspect sites. As @karoolus said, trial and error. Just play around a few sites even if you don't figure it out. You could also see solved sites and try to reach the same solution (or a better one) without necessarily copying the code.--[----->+<]>.++++++++++++.---.--------.
Damn, impressive work. Thank you.
This site definitely has some oddities in it. For example it doesn't seem to work under Linux at all (someone confirm? giving DRM / Shaka error here), and the fact that direct URLs do not work, always need to go through the navigation. Seems like very amateurish work all in all. Your script is a lifesaver. -
Great to see more and more scripts being produced and shared.
Noob Starter Pack. Just download any Widevine media! Over 25,000 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
Hi.
I have been trying to download videos from Eurovision sport, but have failed so far. Earlier, it was easy when they were posting content on Allathletics.tv website.
I tried following the instructions in this thread.
In my windows command terminal, I first installed Python.
Executed : pip install requests pywidevine
I saved the following script by @fme on my desktop and named the file eurovision_download.py:
import json
import re
import requests
LOGIN_API = "https://api.evsports.opentv.com/ias/v2/token?grant_type=password&username={email}&passwor d={password}"
EDITORIALS_API = 'https://api.evsports.opentv.com/metadata/delivery/GLOBAL/vod/editorials?filter=%7B%22editorial.id%22:%7B%22$in% 22:%20%5B%22{video_id}%22%5D%7D,%22locale%22:%22en _US%22,%22isValid%22:true,%22isVisible%22:true%7D& limit=9999&sort=%5B%5B%22Title%22,%201%5D%5D'
def get_token():
'tenantid': 'nagra'
response = json.loads(requests.get(EDITORIALS_API.format(vide o_id=video_id), headers={
video_data = []
continue
try:
except:
'type': 'device',
}, headers={
).content.decode())
return []
keys = []
return keys
if len(keys) == 0:
In the above script, i replaced:
WITH
EMAIL = " my email for eurovision website"
PASSWORD = "my password for eurovision website"
AND
source_url ( in both instances)
with the URL address of page that contains the video:
https://eurovisionsport.com/mediacard/EVS_240612_F_20240707EARome_64
I don't know if so far I am on the right track.
After this i try to run the script. I had saved eurovision_download.py on desktop. I navigated to the path.
Now, I run : C:\Users\***\OneDrive\Desktop>python eurovision_download.py
I get the error : python: can't open file 'C:\\Users\\***\\OneDrive\\Desktop\\eurovision_dow nload.py': [Errno 2] No such file or directory
I would be grateful if someone could help.
*** is my desktop user name.
I don't know much about Python.Last edited by EV Downloads; 17th Jun 2024 at 02:40.
If you intend to use my script for eurovision sport I advise you to use the updated version of it which can be found here.
https://forum.videohelp.com/threads/414548-drm-free-content-downloader-widefrog#post2735651
This site is currently supported.
If Python or l3 cdm is too complicated for you and you don't trust the exe, just drop a txt file with all your videos from that site that you want downloaded and I can generate the download commands for you.
Edit: Here is the download command for your video https://eurovisionsport.com/mediacard/EVS_240612_F_20240707EARome_64
Code:N_m3u8DL-RE "https://evs-ltcu-dash-secure2.akamaized.net/out/v1/6244d2cd22eb4747b82521d44c4e282d/a44b11c8e63146eda52561238d4f2551/547a9906db0d477e9db4ba67ce28f69c/manifest.mpd" --key 2abdaacb56d249839e7650415c5c1423:d93ebeb8c85b889f14aa1a0725e55812 --save-dir "media\eurovisionsport_com" --save-name "EXCLUSIVE_-_Long_Jump_Women_Final" -M format=mkv --check-segments-count false
Thanks for your reply.
This is something that I would need to learn because I am going to keep needing it.
I downloaded your widefrog application but it keeps crashing.
With download command link you provided, I assume I am gonna need this : https://www.videohelp.com/software/N-m3u8DL-RE
But even that application does not run; it crashes. -
That's not really my issue. If you can't get N_m3u8DL-RE for a basic command to work, then you're stuck. You need to install N_m3u8DL-RE and all its dependencies (ffmpeg, mp4decrypt, etc). It was detailed in the post or you can search the forum.
It's been explained lots of times. All you have to do is read. If for some reason N_m3u8DL-RE doesn't work on its own (either you have a dubious OS or 32 bit architecture), someone can download the videos and upload them somewhere for you.
Edit: on second thought if you do have 32 bit architecture, yt-dlp+mp4decrypt might be better since you have the mpd and the keys.--[----->+<]>.++++++++++++.---.--------.
I definitely have a 64 bit OS. That is not the problem. Not just one computer, I downloaded N_m3u8DL-RE on another computer, and the result was the same. A cmd window pops up but disappears instantly.
I later downloaded ffmpeg and put them all together in the same folder ( don't know if that helps), clicked N_m3u8DL-RE, but again it was the same result.
Maybe I am not doing it correctly. I didn't think downloading and running a CLI application would be my biggest challenge trying to do this. -
Programs like N_m3u8, mkvmerge, ffmpeg, mp4decrypt, none of them come with GUI. When you double click it, it opens the CMD, it runs your command, then since it doesnt have "pause" it automatically closes the terminal. Those are programs meant to be executed with parameters from the command line. By double clicking it you arent even passing any parameters. Open cmd, go to your folder and use the tool with the command you want to download.
So, I have the video now, but there is no AUDIO. I thought the audio will start downloading after the video but the screen has been stagnant for sometime. I don't know if something is happening in the background. I have attached a pic of the screen:
[Attachment 79974 - Click to enlarge]
EDIT : Okay...I figured it out. Just needed to hit enter for the audio to start downloading.Last edited by EV Downloads; 18th Jun 2024 at 02:42.
Trying to download this video :
https://eurovisionsport.com/mediacard/EVS_240609_F_20240707EARome_34
I used the following command :
N_m3u8DL-RE "https://evs-ltcu-dash-secure2.akamaized.net/out/v1/9929bb36f9824ba093a01a2c3ef0cd3d/a44b11c8e63146eda52561238d4f2551/547a9906db0d477e9db4ba67ce28f69c/manifest.mpd" --key 2abdaacb56d249839e7650415c5c1423:d93ebeb8c85b889f1 4aa1a0725e55812 --save-dir "HighJump\eurovisionsport_com" --save-name "EXCLUSIVE_-_High_Jump_Women_Final" -M format=mkv --check-segments-count false
I get an option of 5 streams like the Long Jump video I downloaded. I download this video the same way.
But the final output is this:
[Attachment 79986 - Click to enlarge]
[Attachment 79987 - Click to enlarge]
Something goes wrong after the video has been downloaded as evident in the messages given in the terminal. Not just this one, I downloaded a Pole Vault video before this and it had the same result.
Am I giving the wrong command? I downloaded ffmpeg yesterday, i believe it is the latest. The long jump video downloaded fine.
Help obtaining keys
By DenialOfJustice in forum Video Streaming DownloadingReplies: 8Last Post: 28th Jan 2025, 01:34 -
need decryption keys for this
By swappyison in forum Video Streaming DownloadingReplies: 6Last Post: 15th Jul 2024, 14:30 -
Decryption fails with keys
By vwolf in forum Video Streaming DownloadingReplies: 15Last Post: 15th Jul 2024, 14:27 -
not able to find a way for obtaining keys..
By killua in forum Video Streaming DownloadingReplies: 4Last Post: 28th Jul 2023, 03:21 -
Decryption Keys from oneplus.ch
By 3limin4tor in forum Video Streaming DownloadingReplies: 3Last Post: 8th Jun 2023, 00:20
