Page 2 of 4
FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 100
  1. Originally Posted by Obo View Post
    Install Pywidevine (https://pypi.org/project/pywidevine/)
    You can then use this (or a similar script) to read the information:
    import sys
    from pywidevine import Device
    if len(sys.argv) < 2:
        print(f'usage: {sys.argv[0]} <private-key-file> <client-id-blob> or {sys.argv[0]} <file.wvd>')
        sys.exit(1)
    if len(sys.argv) >= 3:
        with open(sys.argv[1], 'rb') as f:
            private_key = f.read()
        with open(sys.argv[2], 'rb') as f:
            client_id = f.read()
        device = Device(
            private_key=private_key,
            client_id=client_id,
            type_=Device.Types['ANDROID'],
            security_level=3,
            flags=None)
    else:
        device = Device.load(sys.argv[1])
    print(device)
    Thanks... It works like a charm
  2. Thank you I am going to save a bunch of these except for the one that a poster said no longer works. I am learning to set up Virtual Enviroments and such trying to get things correct from the get go and isolated.
  3. Originally Posted by Karoolus View Post
    These are 28 individual L3 CDMs (Android Studio, Android 11 iirc):
    https://files.videohelp.com/u/303646/1836941661.zip
    https://files.videohelp.com/u/303646/1874076282.zip
    https://files.videohelp.com/u/303646/1901532735.zip
    https://files.videohelp.com/u/303646/2085943500.zip
    https://files.videohelp.com/u/303646/2090896636.zip
    https://files.videohelp.com/u/303646/2103024377.zip
    https://files.videohelp.com/u/303646/2135508799.zip
    https://files.videohelp.com/u/303646/2163841363.zip
    https://files.videohelp.com/u/303646/2165463467.zip
    https://files.videohelp.com/u/303646/2205156279.zip
    https://files.videohelp.com/u/303646/2225908683.zip
    https://files.videohelp.com/u/303646/2257664396.zip
    https://files.videohelp.com/u/303646/2314085259.zip
    https://files.videohelp.com/u/303646/2343152275.zip
    https://files.videohelp.com/u/303646/2361419202.zip
    https://files.videohelp.com/u/303646/2371137915.zip
    https://files.videohelp.com/u/303646/2373129295.zip
    https://files.videohelp.com/u/303646/2388267602.zip
    https://files.videohelp.com/u/303646/2389746031.zip
    https://files.videohelp.com/u/303646/2408472391.zip
    https://files.videohelp.com/u/303646/2428458567.zip
    https://files.videohelp.com/u/303646/2441727647.zip
    https://files.videohelp.com/u/303646/2448192963.zip
    https://files.videohelp.com/u/303646/2448787606.zip
    https://files.videohelp.com/u/303646/2453587260.zip
    https://files.videohelp.com/u/303646/2464283359.zip
    https://files.videohelp.com/u/303646/2515545258.zip
    https://files.videohelp.com/u/303646/2760340741.zip
    You're welcome
    Thank you very much, i got one today and it works.
  4. Originally Posted by Obo View Post
    import sys
        sys.exit(1)
        device = Device(
            security_level=3,
            flags=None)
    else:
    print(device)
    I dumped my keys from a Samsung Galaxy S4 after upgrading the original stock firmware Android 5.0.1 to custom firmware LineageOS 14.1 - Android 7.1 and that's what I found (but decryption works):
    client_info {
      value: "v4.0.0-android"
    Jan 2023
    Wales
    Thanks Karoolus, much appreciated.
  6. Originally Posted by Karoolus View Post
    You're welcome
    how can i create .wvd file after downloading above file?
    help a newbie
  7. Originally Posted by Obo View Post
    import sys
        sys.exit(1)
        device = Device(
            security_level=3,
            flags=None)
    else:
    print(device)
    File "/home/red/Desktop/test", line 19, in <module>
    AttributeError: type object 'Device' has no attribute 'Types'
    wrong python version ? i use 3.9
  8. How did you execute the script? What arguments did you pass?
  9. Maybe it's PCOK specifically, but I tried 5 of these CDMs and none worked. Maybe they block emulated CDMs now, either that or these are revoked already.
  10. Originally Posted by Obo View Post
    pthon3 test device_private_key device_client_id_blob
    also how can check its a revoked or not any idea ?
  11. I've fixed the script in #29. If you want to check your CDM you should first create a .wvd file from it. Just issue
    pywidevine create-device -t ANDROID -l 3 -k device_private_key -c device_client_id_blob -o .
    If you have your .wvd file you can then use "pywidevine test <your-wvd-file-here>" to check if it is still working or unfortunately revoked.
  12. Originally Posted by Obo View Post
    Thank you my friend working perfect
  13. Originally Posted by Obo View Post
    Is there a similar way to check for revoked cdms for other encryption platforms, like vdocipher?
  14. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    None of these will work for vdocipher
  15. Originally Posted by Karoolus View Post
    @karoolus. Thanks. I have procured a couple of physical cdms. I wanted to check if they have been revoked on vdocipher without experimenting on a real site.
  16. Banned
    Jun 2024
    A naive person
  17. Originally Posted by Obo View Post
    Thank you for doing this.
  18. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Added new CDMs in case the ones I had already posted have been blocklisted
  19. Originally Posted by Karoolus View Post
    ty 👍💯
  20. how can i get own .wvd anyone can help me pls
    [Attachment 81861 - Click to enlarge]
    Sep 2024
    North America
    This command is erroring out for me after unzipping the zip file of newer 30 CDMs, picked one out of 30 at random:
    $ pywidevine create-device -k private_key.pem -c client_id.bin -t ANDROID -l 3 -o .
    INFO:root:pywidevine version 1.8.0 Copyright (c) 2022-2024 rlaphoenix
    INFO:root:https://github.com/devine-dl/pywidevine
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/pywidevine/device.py", line 113, in __init__
        raise DecodeError("partial parse")
    google.protobuf.message.DecodeError: partial parse
    During handling of the above exception, another exception occurred:
      File "/home/dhinchak/code/drm/env/bin/pywidevine", line 10, in <module>
        sys.exit(main())
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/click/core.py", line 1157, in __call__
        return self.main(*args, **kwargs)
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/click/core.py", line 1078, in main
        rv = self.invoke(ctx)
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/click/core.py", line 1688, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/click/core.py", line 1434, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/click/core.py", line 783, in invoke
        return __callback(*args, **kwargs)
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/click/decorators.py", line 33, in new_func
        return f(get_current_context(), *args, **kwargs)
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/pywidevine/main.py", line 197, in create_device
        device = Device(
      File "/home/dhinchak/code/drm/env/lib/python3.12/site-packages/pywidevine/device.py", line 115, in __init__
        raise DecodeError(f"Failed to parse client_id as a ClientIdentification, {e}")
    google.protobuf.message.DecodeError: Failed to parse client_id as a ClientIdentification, partial parse
    This is happening for all 30 of them:
    $ for DIR in `ls | grep _Android_`; do pywidevine create-device -k $DIR/private_key.pem -c $DIR/client_id.bin -t ANDROID -l 3 -o WVD; done
    < .. same error for every single one ..>
    Sounds more like there's something fundamentally wrong rather than revoked/invalid CDMs. Here's my env:
    $ python --version
    Python 3.12.4
    $ pywidevine --version
    $ uname -a
    Linux homelab 6.10.6-arch1-1 #1 SMP PREEMPT_DYNAMIC Mon, 19 Aug 2024 17:02:39 +0000 x86_64 GNU/Linux
  22. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You should really start reading what other people post. The answer is in the same page of this post
    https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here!/page2#post2743556
  23. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Even if the CDMs were revoked, I don't think a local command would throw an error when creating the WVD.
  24. Member
    Aug 2023
    Turkey
    it is so if its revoked you cant build WVD
  25. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    I just tried with the revoked CDM, as reported here:
    Originally Posted by LittleSoldier View Post
    For Info :
    This one is already revoked Karloos but anyways you've provided us with enough CDMs
    [Attachment 81915 - Click to enlarge]
  26. Doesn't seem like it:
    > pywidevine test .\unknown_android_sdk_built_for_x86_16.0.0_9d1ea0a0_8162_l3.wvd
    INFO:license:[+] Loaded Device (8162 L3)
    INFO:license:[+] Loaded CDM
    INFO:license:[+] Opened CDM Session: 99d186497a032ed8b33bfbb97cb9e8b8
    INFO:license:[+] Created License Request Message (Challenge)
    INFO:license:[+] Got License Message
    INFO:license:[+] License Parsed Successfully
    INFO:license:[SIGNING] 00000000000000000000000000000000:bdff2a1f1f05166d942b27c0c4776f90127e7c8c18b60322f0e110db6f0b207e2587631553edbddc01999c48936aecc12032215d5cfd6a464629476a35ce2ae4
    INFO:license:[CONTENT] ccbf5fb4c2965be7aa130ffb3ba9fd73:9cc0c92044cb1d69433f5f5839a159df
    INFO:license:[CONTENT] 9bf0e9cf0d7b55aeb4b289a63bab8610:90f52fd8ca48717b21d0c2fed7a12ae1
    INFO:license:[CONTENT] eb676abbcb345e96bbcf616630f1a3da:100b6c20940f779a4589152b57d2dacb
    INFO:license:[CONTENT] 0294b9599d755de2bbf0fdca3fa5eab7:3bda2f40344c7def614227b9c0f03e26
    INFO:license:[CONTENT] 639da80cf23b55f3b8cab3f64cfa5df6:229f5f29b643e203004b30c4eaf348f4
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  27. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    I didn't check, but maybe I'm too gullible..
  28. Naah. Building a wvd from cert/pem and blob works without internet access, and thus even if the CDM is revoked, building won't fail for that reason. You can check the code. To my understanding wvd is just another format probably invented by rlaphoenix to serialize a cdm.
    If the local components even don't have knowledge of being revoked: how can building a wvd from cert/pem/blob possibly fail for that reason?
  29. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    That's what I thought as well. I think wvd is a concatenated version of the 2 separate files
