Hi folks,
Recently upgraded Subtitle Edit from v3.6.8 to v4.0.3.
Noticed fairly quickly that the waveform from a previous session
does not reappear as it used to. Have to click on window to regenerate.
In the waveforms folder
(C:\Users\Augustus\AppData\Roaming\Subtitle Edit\Waveforms)
to test, I backup the old XXXXXXXXX.wav file before generating
a new one. The CRC32 is exactly the same for both files.
So, I guess for some reason, it doesn't know that the waveform
has already been generated. Or, it doesn't do the check in the
first place.
How can I get the waveform from a previous session to load
automatically and avoid wasting 2 minutes to regenerate the same file?
Results 1 to 1 of 1
Waveform and spectrum app ?
By max_cady in forum AudioReplies: 3Last Post: 5th Jan 2023, 13:58 -
How to cut a waveform above certain db level with ffmpeg?
By qo4on in forum AudioReplies: 26Last Post: 22nd Nov 2022, 07:42 -
why does my waveform stutter like this?
By benten in forum SubtitleReplies: 2Last Post: 8th Jan 2020, 16:19 -
Old multi-session CD. 2 sessions. Only last session shows in Win. explorer.
By bteddy1 in forum Newbie / General discussionsReplies: 3Last Post: 20th Mar 2019, 11:19 -
waveform problem in Subtitle Edit 3.4.6
By whitelighter27 in forum SubtitleReplies: 2Last Post: 15th Mar 2019, 07:14
