Thanks. Source was 25fps (no slowdown), hence the applied pulldown flag pattern was for 25->29.97.
From the log:
So while DVDStyler (the proposal in post#18) converted the framerate by repeating certain frames, AVS2DVD applies soft-telecine (means providing pulldown instructions for the player) by flagging the stream accordingly (using the flags 'Repeat_First_Field' and 'Top_Field_First').<07.03.2024 19:27:40>
START PULLDOWN OPERATIONS
DGPulldown Parameters: "D:\....\DVD_VTS_01_1.m2v" -srcfps 25 -destfps 29.97 -inplace -tff
When ticking the PAL->NTSC slowdown option it produces the standard 3-2 pulldown pattern which is perfect for NTSC compliance and minimizing judder.
From the log:
DGPulldown Parameters: "D:\..........\DVD_VTS_01_1.m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
Results 31 to 44 of 44
My 15 year old Sony HD 1080p TV cannot, but I have a roku player that will.
As said, get him via amazon a modern dvd player that will play worldwide dvd's. However when you make a copy you will remove region encoding and many many North American dvd player of old will play pal DVD's on a ntsc TV, your milage will vary.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
If your friend is local take your dvd over and may be just may be it will play. if not use a dvd decrypter to make a copy, I am interested-whats the film?
Use Avidemux to remux the contents into an mpg-ps file, then use DGindex on the mpg
to create the project and demux the audio. (file/save project)
A second method, is to use the MKV directly, I'm going to test it to see if it all works. (It works, perhaps try this first)
Before loading your source, set the Preferences and save them.
Avisynth tab -
AVS video source filter- ffmpegsource
AVS audio source filter - ffmpegsource
Use NTSC slowdown for progressive PAL (select)
Video tab -
DVD video standard - NTSCLast edited by davexnet; 11th Mar 2024 at 02:28.
A2D's normal operation is to maximise the file size so it will best fit the DVD, ie. up to 4.5GB
the assusmption is you're going to be burning an actual DVD - if you're going to do that,
may as well maximise the bitrate
If you'd like to reduce the bitrate, you can do it from Title edit/video tab.
One scenario where this is useful is if you want to create an mpg file vs. a physical DVD.Last edited by davexnet; 11th Mar 2024 at 12:36.
properly resizing pal dvd to 480p with lanczos
By codemaster in forum DVD RippingReplies: 21Last Post: 13th Oct 2023, 15:42 -
VHS recorded on PAL (UK) trying to convert to digital in USA (NTSC)
By MomOfOne in forum MediaReplies: 11Last Post: 10th Aug 2023, 19:17 -
Which software converts Mpeg2 NTSC to PAL / PAL to NTSC, WITH speed change?
By guy24s in forum Video ConversionReplies: 22Last Post: 27th Jul 2023, 03:42 -
Could a PAL/NTSC Video Converter be used to capture PAL VHS from NTSC VCR?
By hpcampr in forum Capturing and VCRReplies: 10Last Post: 24th Jan 2023, 15:42 -
Convert PAL DVD with blended frames back to NTSC?
By WWEF in forum RestorationReplies: 2Last Post: 30th Dec 2021, 00:20
