Anyone know of a device that'll play flacs/wav files on a USB stick, that has RCA audio phone outputs?
And preserve the audio quality, not downsample etc.
Thanks.
A computer with audio in/out jacks.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Is there a USB HDMI capture device that handles 50fps?
By AVR2 in forum Capturing and VCRReplies: 3Last Post: 4th Jun 2023, 20:47 -
[Solved]USB capture device stuck on 10 fps
By sebus in forum Capturing and VCRReplies: 42Last Post: 22nd Feb 2022, 11:14 -
chinese usb 3 device capture
By codebox in forum Capturing and VCRReplies: 28Last Post: 21st Jul 2021, 15:20 -
What is a good USB Capture Device to use with VirtualDub?
By anachronon in forum Capturing and VCRReplies: 12Last Post: 2nd Mar 2021, 16:56 -
Hi8 through DCR-HC40 or USB device?
By Gottria in forum Capturing and VCRReplies: 4Last Post: 18th May 2019, 12:30
