Hi
<-- a cat here
I compare some NLEs to understand if someone can do "my" good old function of kindly treating the clips encountered during drag&drop on the timeline. Speed Razor in my opinion is the best because it doesn't invade the clips have already been positioned. Does anyone have an idea if this correct behavior can also be reproduced in other NLEs besides seep razor
please whatch this:
https://www.swisstransfer.com/d/7c0474ff-3d29-4653-9590-a0cc2559b28d
That was discussed like 5 years ago, still no resolutions for this?
The best is what you are used to do. What you are trying to do is not using auto ripple (that how Vegas calls it). Did you try manuals for those particular software in your demonstration (Premiere, Edius, DaVinci Resolve)? That could be turned off, just a guess and then watch what it does.
I use Vegas (not in your demonstration) and you can turn it off. Then clip is just inserted within a gap but that inserted clip is overlapping old ones. Those overlapping parts become transitions automatically, you have to drag ends to those gap borders to get rid of it, then using slipping tool to find proper frame to start in gap etc. Or just drag ends manually everyone does it differently.
So Vegas would not do what you want. Besides having track priority from top, like Premiere. Your Speed Razor has it the other way, priority from the bottom. -
https://www.swisstransfer.com/d/132ada8a-eefa-4bc6-8be7-aa307217fdfe
please help the cat -
This has been discussed before (in fact, I have told you this before) - I know Premiere can do what you want, and so can Media Composer, and pretty sure Edius as well. In fact, most better NLEs can do this, but you have to select the edit mode you want. Different apps may use different terms for the same thing, so you will have to do some homework to translate between the terms.
Subtitle Edit: Sup export - Bottom Margin all over the place
By seamus11 in forum SubtitleReplies: 6Last Post: 4th Jul 2022, 04:05 -
App to edit without re-encoding (ie. avidemux) but with a timeline? AviUtl?
By asdfg9 in forum EditingReplies: 2Last Post: 12th Jan 2022, 09:02 -
How to move this clip,which was so middle of the timeline, to left side?
By Ganesh Ujwal in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2020, 11:01 -
VSDC Small Clip Edit
By Landoe in forum EditingReplies: 2Last Post: 7th Apr 2020, 09:30 -
MPC- Can I edit Clip Properties?
By smike in forum EditingReplies: 2Last Post: 26th Apr 2019, 09:27
