I recently installed a pinnacle DC10+ in my Duron 800, I never tested the camera (after the DC10 installation) before I had to reformat the H/D, so I dont know if the problem existed then.
After the reinstall of everything I got to installing my Quickcam express, no dice..... the quickcam program opens it comes up with a pop up to select the capture device, which after 3x pressing OK, the prog opens with the mess "The logitech quickcam express device is currently being used by another application".
I've tried turning off the pinnacle device in control panel, have tried turning off everything bar the essentials in [ctr] [alt] [del], still no go.
How do I turn off the capture card fully, as I think that is the root of my problem.
TIA, Lumpy
Results 1 to 1 of 1
'Tis better to be shut up and let everyone think you are an idiot, than to open your mouth and remove all doubt.
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 09:33 -
Logitech Quickcam 9000 Pro
By Tyler2000 in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2008, 15:22 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 21:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 10:02
