  1. I would like to know how to convert MPEG2 to MPEG1, so I can burn a Spiderman VCD to play on my DVD player....
    May 2002
    Rainy City, England
    Demux the SVCD mpg using TMPGEnc's mpeg tools. Use the audio and video files as input to TMPGEnc and re-encode using a VCD template.
    To do it properly you really need to join the 3 SVCD mpgs first and split in half. Then do the demux and re-encode as mentioned at the start.
  3. TMPGEnc will not take the MPEG-2 input without an MPEG-2 codec or filter installed - you can get both in the "tools" section here
    you could also use DVD2AVI -- load up all 3 SVCD MPEG-2 files into DVD2AVI - create 1 project file and then convert it to VCD
    check the Convert "how to" guides
    <---- over there
    your pal,
    Stinky
