Been looking for a mobile SD video storage solution to go with a SDI capture device for analog tape materials to replace the computer in certain situations, The goal is to record the lossless files then come back home, dump the files into the computer for processing.
I came across the Blackmagic Design HyperDeck Shuttle 2 that supposedly can record digitally from a SDI output in lossless quicktime, It is compliant with SMPTE 259M, rec. 601 for SD SDI which is suitable for the capturing task. My question is, how manageable Quicktime files are in a PC environment? and is Quicktime truly lossless or is it just like ProRes? Which by the way it does additionally support.
Using Virtualdub What is the Best Codec to Capture and Best Codec to Save?
By mjgreer in forum Newbie / General discussionsReplies: 32Last Post: 11th Dec 2024, 03:32 -
Question about $10 HDMI Recorder
By jimdagys in forum Video Streaming DownloadingReplies: 27Last Post: 19th Nov 2022, 09:48 -
question about how to play video on portable mp4 player
By jimdagys in forum Portable VideoReplies: 15Last Post: 5th Apr 2021, 22:56 -
Recommended < $100 portable digital audio recorder?
By yetanotherlogin in forum AudioReplies: 0Last Post: 18th Aug 2020, 05:00 -
[SOLVED] Can you identify this portable audio recorder?
By yetanotherlogin in forum AudioReplies: 2Last Post: 13th May 2019, 15:44
