I have been trying to find the answer to this for a while. I have thousands of mp4's that need to be authored and burned to DVDs. Each mp4 gets its own DVD and they all run in length less than 3 hours. Right now, I author one at a time using PowerDirector, save it as an ISO, and then burn the ISO using the generic Windows burn tool. A painstakingly long process.
Is there any possible way that I can batch author all the mp4's to either ISOs or a burnable DVD folders? Is there any software that can do this? I don't mind if I have to sort the files via duration to set the correct bitrate, but there has to be an easier way to do what I am doing.
NO menus are needed for any of these.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
try what is in this thread post #8 - https://forum.videohelp.com/threads/331480-Batch-Convert-ISO-DVD-to-MP4
Making DVD from Mp4, .... I have windows batch scripts that make ISO's or DVD's (or even burn it, if DVD is in a tray), using Avisynth (other apps are included: HcEncoder, ImgBurn, muxman, mediainfo cli, BePipe, aften ... but from avi files.
It would need to be modified. Searching for avi strings in bach script and replacing it with mp4 and changing avisynth source plugin.
I do not feel like modifying it, but if you do not mind digging in it, knowing windows batch script, I could post a zip with everything. -
That would be great thank you. I'm pretty familiar with batch script so I should be able to do this.
The link is still ok after years: https://files.videohelp.com/u/198160/Dmfs%20Avi%20to%20MP4-DVD.zip ,
so you look for _AVI_to_DVD.BAT, all references to avi you have to tweak to accommodate as mp4, then make sure you customize your INI and pass it with your filename. How to use it is in the begging of the script. There is a lots of examples for those INI files.
That BAT has 840 lines, don't freak out . It is structured well with lots of functions, so it is readable. Use Notepad++ and set language to Windows Batch Script. Do not use notepad etc., it would not be readable, some color highlights are needed while looking at the code. -
Besides all changes, like changing .avi for .mp4 and more stuff. On line 188, there is a first avisynth script line created and it is:
Code:echo AviSource("%aviname_input%") >> "%temp_adr%.avs"
I forgot what I was doing with audio, but perhaps you need to load first lines including audio:
Code:echo LSMASHVideoSource("%aviname_input%") >> "%temp_adr%.avs" echo LSMASHAudioSource("%aviname_input%") >> "%temp_adr%.avs" echo AudioDub(v, a) >> "%temp_adr%.avs"
Best way to batch convert DVDs (MPEG-2 VOBs) to H264?
By gs684 in forum Video ConversionReplies: 2Last Post: 21st Jan 2024, 17:14 -
ISO To MP4
By Spottedfeather in forum Video ConversionReplies: 5Last Post: 12th Jan 2022, 11:47 -
ISO to MP4
By Steved2021 in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2021, 07:47 -
Rewrap MTS to MP4 w/o re-encoding. Why is MP4 smaller? GUI batch tool?
By Razz in forum Video ConversionReplies: 7Last Post: 13th Mar 2021, 17:24 -
Batch rip ~100 DVD .iso images with 3 episodes each, multi audio and subs
By rawyolks in forum DVD RippingReplies: 6Last Post: 12th Jan 2020, 04:53
