Hi
iam trying to demultiplex the audio (ac3) from a divX video with virtualdub as it is said above. but the size of the output file is only 1k. same with nandub. the video plays fine with sound
could sb help me plz?
thx
Results 31 to 44 of 44
Stinky I love u !!!!!!! Ok well nearly
4 hours later having utilised ever god damn ac3 converter but to no avail. Your original method is the only thing that worked. I'm gonna sleep well tonight...........
p.s. Damn those smart arse xvid AC3 weilding maniacs
Does anyone have a ZIP file (or can anyone make it from those files) of headac3he-0.23a.rar, I can't open the RAR.
Please mail it solibic@hotmail.com, the file isn't big i think, not 1 mb I hope so..
Thanks in advance! -
Thanks for the above guide I have been scratching my head over this one for over a week. I still have a problem, the film I have is in two Avi files. I joined the two in VirtualDub 1.4.12 extracted the audio and used HeadAC3he to convert to wav. However it craps out at the point the two have been joined. So I extracted the audio from both files separately and converted to wav’s with HeadAC3he. I joined the two wav’s with Nero’s wav editing prog. I have converted the video with TMPGEnc Plus v2.59.47.155 to mpeg2 using the DVD template (trying to make a DVD). When I try to multiplex the Mpeg2 Video to the audio wav file using TMPGenc tools I get the following “multiplexing linear PCM stream to system stream is not supported”. Can someone explain what I’m doing wrong or know away around this?
Stationx -
Well I've been having problems as well - both aviwav33 and VirtualDub were taking the audio off my DivX avis ok, but nothing could seem to save the AC3 audio files as normal Windows wav files.
Then I read the above posts and used Nero Wave Editor and it did it perfectly. Thanks to all for the info. Now can make decent VCDs of them....
cheers
Diz
I have been trying all of these, and i cant seem to get it to work!
but the problem lies in the virtualdub > direct copy!
I cant get a good .ac3 out of it, none of the ac3headace, beegeez, ac3 ac3 and all of that can use them! im only getting alot of errors, but it layes in the corrupt frame 1 and such!
is there another tool for extracting, demuxing the avifile with ac3?
tried virtualdub and nanodub, but none of them seems to work!
on two movies! -
For the below process to work I had to use the following file:
http://www.digital-digest.net/downloads/files/encode/ac3fix.zip
Now all the files I extracted using VDUB are being accepted as true AC3 files.
Originally Posted by Stinky -
Sorry to find faults, but the guide says ;
"Convert A DivX with AC3 To VCD"
But the only thing it seams to cover is saving out the audio and converting it to a .wav Which has already been covered by other guides.
Why not just say in your guide;Now you have your original DivX and the AC3 audio mixed down to WAV
put them into your VCD/SVCD encoder and your ready to go
Convert the .AC3 to .WAV and then put them into your VCD/SVCD encoder and your ready to go
No need for any explanation then ?
KingJohns Guide AVI Audio
For those people who are having problems with HeadAC3he it does say on the web site to download the DLL's you will also need to use with it.
http://mitglied.lycos.de/darkav/svcdguide/svcd.html -
I had two .avi xvid files that I joined in VirtualDub MP3 Freeze and then used Goldwave to save off the ac3 stream in a .wav file just fine. The problem comes when I encode to DVD format. I play the files in the VIDEO_TS folder in PowerDVD and it looks okay but the sound slowly gets ahead of the video and after 30 minutes the sound is 5-10 seconds ahead of the video. Any ideas why? I have used Ulead MovieFactory, CCE SP, TMPGEnc, and IfoEdit95 to encode to DVD format. The sound format is 48 KHz. Does this need to be 44 KHz to keep with the video?
Ok i am a newbie.. and i am a little confused once you sperate the audio from the divx movie, and done that process how do you combine them in tmpgenc????? or what are you susupose to do with that audio???
This was mentioned up front as being problemmatic, but I have never had a problem doing it like this (and so far ignorance is bliss
I take my DivX file with the AC3 audio and run it through decompress.exe (which is in the dvd2avi.zip file). This takes only a few minutes on a fairly fast computer and adds "_pcm" to the end of the file name of the DivX file. Then I just use that blahblah_pcm.avi (as an example) file as the source for both the video and audio in TMPGenc and follow the normal process for making a VCD/XVCD. If the audio isn't 44,100 I just let TMPGenc fix it on the fly. So far I have yet to get a VCD or XVCD out of this process where the audio is out of sync (unless it was out of sync in the DivX file, in which case you can fix that with VirtualDub).
I highly suggest you try this method before you go messing around with wave editors and such. Not that they won't work too - just that this method is so much easier and so far ... seems bulletproof.
YMMV, etc.The shortest sentence is said to be "I am". The longest is "I do". -
There are many, many tools, that are able to convert ac3 to wave.
The point about using headach3e is, that headache is able to make a ProLogic II conversion.
And if you do this proper, and if you do have the right equipment (meaning a reciever that is able of ProLogic II decoding and set of 5 speakers and a subwoofer) you will hardly notice a difference between this (mp2-Stereo sound, should be at 160 kbps) and the original DD 5.1-Sound.
Give it a try - it's f***ing great!
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Convert divx avi with dts to ac3
By mk15 in forum AudioReplies: 3Last Post: 23rd Jun 2009, 03:46 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
