  1. I'm currently using a Panasonic 860, and i've noticed this clicking noise when i start capturing (before i play the tape) so on the blank AV screen, it's there, and it continues to play in the background when i play the VHS, more noticeable during quiet moments on the tape. It's very distracting.
    Mar 2008
    Some kind of electrical problem or interferemce. Try connecting the VCR directly to the TV via the composite/s-video and the red and white analog audio. (Or Scart if that's all you have)
    If you can still hear it, try a different set of cables.
    If you can still hear it, probably an issue in the VCR
  3. I'm a Super Moderator johns0's Avatar
    canada
    Does the clicking sound go down when you turn the volume down?
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Make sure your phone is nowhere near your VCR......been there done that.
