I'm hunting for a (preferably small rather than huge bloatware, but at this point I'll take what I can get) a windows program that I can load a video, use the scrubber (and/or directly entering in the timecode in a text field) to go to the specific times in the video, mark it as a chapter, enter the chapter title, etc., and when I'm finally all done creating chapters, be able to export that list of timecodes and titles to a file that MKVToolNix recognizes as a chapter file and can import it.
Ultimately, the goal is simply to visually be able to create my chapters and then add them to the video using ToolNix.
I've had the WORST time trying to find what seemingly would be out there already. Almost all chapter editors, including the built-in one in ToolNix only let you manually enter timecodes and titles without being able to actually SEE where they are within the video file, so you have to use some other video video player, and bounce back and forth between that and (i.e. ToolNix) memorizing the timecode each time, which is cumbersome. I actually cringe when I think "man, I need to add some chapters to this video, but I have to do that annoying 'chapter dance between apps'", and that already starts me out in a cranky mood.Often ending up just procrastinating eternally.
The closest I've come is the old VideoReDo, but the 'mark & chapter export to .txt' only adds the timecodes to the txt file in a format ToolNix doesn't recognize, so ultimately not useful to me for this.
TL;DR
I'm looking for a visual chapter editor for my videos.
Does anyone know?
TIA!
Open MKVToolNix GUI in Header Editor by default (instead of Multiplexer)
By Moutya in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2026, 14:29 -
Using MKVtoolnix Chapter Editor
By hurricane1951 in forum EditingReplies: 25Last Post: 13th Feb 2023, 06:56 -
Video Editor Recommendation!
By Valentin98 in forum Software PlayingReplies: 12Last Post: 11th May 2022, 13:09 -
Recommendation for Best Video Editor
By Inky22 in forum EditingReplies: 2Last Post: 8th Feb 2022, 13:06 -
Recommendation on a lightweight foss video editor?
By Chemist116 in forum EditingReplies: 1Last Post: 7th Nov 2021, 11:59
