i need to run curl command, multiline like this one:
but cmd run each line separately. so, with first line i get all elements from web page, but idk how run right full commandCode:curl -s "https://link" \ | grep -oP '<img src="\K[^"]*' \ | head -n1
Results 1 to 11 of 11
thanks for your reply, but same behavior. also with curl only (not cmd/powershell)
my goal is download the file
found trough Elements tab:Code:https://i1.sndcdn.com/artworks-4KDEzUk5fgjxkLoT-4kINZA-t500x500.jpg
[Attachment 77338 - Click to enlarge]
here the full command
unlucky the kind user who gave me this command did not answer any further, and left me in doubtCode:curl -s "https://soundcloud.com/defectedrecords/defected-radio-show-most-rated-special-hosted-by-sam-divine-221223" \ | grep -oP '<img src="\K[^"]*' \ | head -n1
here my log:
Code:D:\curl-8.6.0\bin curl -s "https://soundcloud.com/defectedrecords/defected-radio-show-most-rated-special-hosted-by-sam-divine-221223" \ <!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8"> <meta name="theme-color" content="#333"> <link rel="dns-prefetch" href="//style.sndcdn.com"> <link rel="dns-prefetch" href="//a-v2.sndcdn.com"> <link rel="dns-prefetch" href="//api-v2.soundcloud.com"> <link rel="dns-prefetch" href="//sb.scorecardresearch.com"> <link rel="dns-prefetch" href="//secure.quantserve.com"> <link rel="dns-prefetch" href="//eventlogger.soundcloud.com"> <link rel="dns-prefetch" href="//api.soundcloud.com"> <link rel="dns-prefetch" href="//ssl.google-analytics.com"> <link rel="dns-prefetch" href="//i1.sndcdn.com"> (cut) ...... ....... D:\curl-8.6.0\bin | grep -oP '<img src="\K[^"]*' \ | not expected D:\curl-8.6.0\bin | head -n1
finally i've get right command to rip and print jpg link with:
Code:curl -s "https://soundcloud.com/defectedrecords/defected-radio-show-most-rated-special-hosted-by-sam-divine-221223" | awk -F'"' '/<img src="https:\/\/i1\.sndcdn\.com\/artworks-.*\.jpg/ {print $2; exit}'
now i need to automate the full process and download this jpg file. how to ?Code:https://i1.sndcdn.com/artworks-4KDEzUk5fgjxkLoT-4kINZA-t500x500.jpg
edit command from my first post, get jpg link (removed < before 'image', and put command on a single line)
but still idk how to download ...Code:curl -s "https://soundcloud.com/defectedrecords/defected-radio-show-most-rated-special-hosted-by-sam-divine-221223" | grep -oP 'img src="\K[^"]*' | head -n1
problem solved (thanks to chatGPT). here 4 alternative ways
this command, trough curl, download jpg file with original filename (put link on command above)
or this "artwork.bash" use curl, required link, save with original filename jpg (copy code above, save as artwork.bash and run it from curl folder)Code:curl -s "https://link" | grep -oP 'img src="\K[^"]*' | tail -n 1 | xargs -n 1 sh -c 'curl -o "$(basename "$0")" "$0"'
another script use python, with curl, required link, save with original filename jpgCode:#!/bin/bash read -p "Enter the SoundCloud link: " soundcloud_link curl -s "$soundcloud_link" | grep -oP 'img src="\K[^"]*' | tail -n 1 | xargs -n 1 sh -c 'curl -o "$(basename "$0")" "$0"'
another command use yt-dlp to downloadCode:import subprocess import os def extract_image_url(soundcloud_link): curl_command = f'curl -s "{soundcloud_link}"' curl_output = subprocess.check_output(curl_command, shell=True, text=True) # Extract the image URL directly in Python for line in curl_output.split('\n'): if '<meta property="og:image" content="' in line: image_url = line.split('<meta property="og:image" content="')[1].split('"')[0] return image_url raise ValueError("Image URL not found") def download_image(image_url): filename = os.path.basename(image_url) subprocess.run(['curl', '-o', filename, image_url]) if __name__ == "__main__": soundcloud_link = input("Enter the SoundCloud link: ") try: image_url = extract_image_url(soundcloud_link) download_image(image_url) print(f"Image downloaded successfully! Saved as: {os.path.basename(image_url)}") except Exception as e: print(f"Error: {e}")
Code:import yt_dlp URL = input('soundcloud link: ') ydl_opts = { 'writethumbnail': True, 'skip_download': True, } with yt_dlp.YoutubeDL(ydl_opts) as ydl: info = ydl.extract_info(URL, download=False, process=False) thumbnails = info.get('thumbnails') or [] info['thumbnails'] = [t for t in thumbnails if t.get('height') == 500] ydl.process_ie_result(info) -
use curl -s -o "defected_radio.jpg" to download the image
curl to scrape the soundcloud URL, grep "<img src=.http" to capture the required line, awk "BEGIN{FS=\"\042\"} {print $2}" to parse the line and get the image name and lastly xargs curl -s -o "defected_radio.jpg" to feed the image name to curl and then download the image to current directory.
here is the complete code
Code:curl -s "https://soundcloud.com/defectedrecords/defected-radio-show-most-rated-special-hosted-by-sam-divine-221223" | grep "<img src=.http" | awk "BEGIN{FS=\"\042\"} {print $2}" | xargs curl -s -o "defected_radio.jpg" -
thank you jack for your advice, but what difference (advantage) from my curl command above ?
Advantage ... absolutely none
Difference ... Your code is for linux. The code I provided is for Windows.
I posted because some other person, using windows, may wish to do the the same as you.
I tried to show that piping does not require multiline. Multiline is used when the line of code is very long and you wish to show it confined to a smaller space. -
thanks for your clarification.
however i am win user, i don't use linux ...! and my command above post#6 for curl or also bash file, work great on windows
also my command above (thanks to chatGPT) save file with original filename, without edit manually curl command for -o "defected_radio.jpg"
also bash file ask each time new soundcloud link. this allows to use bash file with different links without edit curl command
Need curl command to extract m3u8 url
By tonygables in forum Video Streaming DownloadingReplies: 2Last Post: 26th Feb 2024, 01:11 -
Need curl command to extract m3u8 from live TV website
By tonygables in forum Video Streaming DownloadingReplies: 5Last Post: 25th Apr 2023, 05:10 -
Curl or Wget command to capture vtt subs?
By daigo99 in forum SubtitleReplies: 3Last Post: 5th Sep 2021, 20:16 -
Divide each line of text into new subtitle line
By martanius in forum SubtitleReplies: 1Last Post: 11th Apr 2021, 16:21 -
Multi-line, heavily stylized subtitles (ASS) possible on Blu-ray?
By Deli295 in forum Authoring (Blu-ray)Replies: 12Last Post: 25th Jan 2021, 15:41
