I use anydvd hd to rip my 4k disks to iso, they are rougly 80-90GB in size. My question is how do I burn them to a standard BDXL (100gb) blank and will my 4k player (xbox series x) then play them? the burning software I have is cyberlink power2go which burns blurays and iso files, could I use that?. I am new to burning iso rips. I just want to preserve the original quality and menus that is why I use anydvd hd
No, there is only 1(!!!) Panasonic player that will play burned BD-XL discs. If you want to keep the original quality you should investigate players like Oppo Clone, Zidoo etc. that can play the ISO file or a folder structure from hard drives.
The Andriod version of Kodi probably works better for playing UHD MKV files than it does for UHD Blu-ray ISO files, especially when streaming from a home network.
Zidoo and Dune HD Pro 4k/8k and some other similar high-priced media players are supposed to have built-in support for UHD Blu-ray ISO playback.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Compatibility of multilayer burnable discs (compared to pressed multilayer discs) drops precipitously over 66GB.
BluRay Player with BDXL Support
By Jake802 in forum DVD & Blu-ray PlayersReplies: 567Last Post: 11th Dec 2025, 01:14 -
Changed HDMI switch, now BluRays have no sound
By g68 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Jan 2024, 16:31 -
BluRays not working on desktop PC
By magnu in forum DVD & Blu-ray WritersReplies: 12Last Post: 30th Jun 2022, 12:37 -
.ISO to BD
By muddy7 in forum Authoring (Blu-ray)Replies: 3Last Post: 24th Nov 2021, 17:35 -
BDXL 55GB MKV File
By michaelsft in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Mar 2021, 09:50
