I wish to silence the beginning of a dtsma track (which I've already extracted) for a specific time interval, with a resolution of 1 ms. How do I do that?
Results 1 to 9 of 9
There is no way to do this directly in the compressed (DTS) domain, so you would have to decompress to LPCM, do the silencing with a standard audio editor, and re-compress to DTS (losing some quality in the process).
Scott -
Ugh, that doesn't sound pretty (no pun!). I think I'll leave it as is. Edit: How about if I just lop off the start of the track for a specified interval?
While there is a tool that has some capability to do that for mp3 and mp4/aac, I know of no tool that can do that for dts. If one does exist, there would also be limits to the time resolution/atomicity, due to the way dts uses buffered chunks in its time domain compression.
Scott -
Thanks Scott. It sounds like 1 ms resolution is overly ambitious. Do you think 0.1 second might be doable?
I'm wondering if cutting on keyframes wouldn't be necessary if there's no video?
Try to import only the dts track in MTX. In the Output tab, set your desired Split mode and values. Mux to *.mka.
Does this work? I actually never tried...
Do I need to keep the AC3 track if I am keeping a DTS, DTS-HD MA, TrueHD?
By MarioVideo in forum AudioReplies: 6Last Post: 14th Oct 2023, 04:43 -
Need help/guidance converting TrueHD audio track in an MKV to DTS-HD.
By fluxcapacitormb in forum Newbie / General discussionsReplies: 12Last Post: 8th Oct 2023, 03:51 -
How to change audio speed starting from DDP, DTS-MA, AC3 or DTS core?
By precipizio in forum AudioReplies: 0Last Post: 22nd May 2022, 09:28 -
XMedia Recode won't detect DTS track of a movie
By xu5bo5yang in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2020, 01:53 -
Mix new THD or DTS track from Original and other language AC3
By tcmaps in forum AudioReplies: 0Last Post: 5th Jun 2020, 16:50
