Hi i want to covert a MOV file to MPEG but i dont know where to get a converter from can somone help me?
i usually dont use cracks but if you use quicktime 5.0 pro you can export the .mov vidz to .avi and then uncompress them with VDub and convert to vcd
prophet,
If you are using TMPGEnc, then a plugin is available to load MOV file for encoding. Look for it on the lef in the CONVERT section.
BeTa -
You can't use the TMPEGEnc plugin while having Quicktime 5.0 installed. You can either do what mvdude2001 said, which I don't recommend because the selection of codecs is atrocious. Or (recommended for maximum quality), install Quicktime 4.0 (non-pro, standard freeware version), and follow what BeTa said, by using the QTReader.vfp plugin with TMPEGEnc.
Do you know of a site where we can obtain QuickTime 4 from LighthouseJ?
Cheers! -
I transfer the the MOV file with mov2avi.exe and then i start the TMPGEncoder, choose AVI file as video source and the MOV file as audio source. Works fine every time.
Thank You! -
I tried using 5.5 quicktime and the method using TMPEGenc and I get Audio but no video. Yet I can convert the MOV file to AVI no Problem. But, to convert AVI to MPEG all audio and no VIDEO. Any ideas?
Thanks John -
Thank You!
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Where can this mov2avi.exe converter be found?!!?!?!
I have been struggling to get an AVI/Wav audio source from a mov as my TMPGEnc12i leaves the audio off my mov to Pal SVCDs.
Converting .dv and .mov Mac file to MPEG-2 No Audio
By RL in forum ffmpegX general discussionReplies: 3Last Post: 30th Jan 2011, 05:47 -
Converting MOV to MPEG-2 File
By cyberboy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 17:39 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
Converting MOV -> MPEG-2 (or AVI or...)
By Sean-PH in forum ffmpegX general discussionReplies: 5Last Post: 10th Jan 2008, 13:35 -
problem converting one little file to mpeg MOV (any ideas why)
By bdaul in forum ffmpegX general discussionReplies: 5Last Post: 1st Jan 2008, 08:32
