Page 3 of 3
FirstFirst 1 2 3
Results 61 to 87 of 87
  1. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    That's cause you're downloading vp9 content which is kinda buggy for n_m3u8dl-re when it comes to decrypting. Run those commands separately
    N_m3u8DL-RE "https://vcze180.cda.pl/15210174vp9/15210174.mpd"
    shaka-packager in=video_encrypted.webm,stream=video,output=video_decrypted.webm --enable_raw_key_decryption --keys key_id=30323861366531373232363138353865:key=33633361636663373236313933353439
    shaka-packager in=audio_encrypted.webm,stream=audio,output=audio_decrypted.webm --enable_raw_key_decryption --keys key_id=30323861366531373232363138353865:key=33633361636663373236313933353439
    mkvmerge video_decrypted.webm audio_decrypted.webm -o video.mkv
    Your video
    https://www.swisstransfer.com/d/a276a2cd-e0d9-4dc6-8ac6-49817eb93858
    Feb 2006
    Originally Posted by Henryk69 View Post
    I have a link to a film from da.pl
    https://www.cda.pl/video/1521017489/vfilm
    From Widevine Proxy2 I downloaded the command to CDM
    N_m3u8DL-RE "https://vcze180.cda.pl/15210174vp9/15210174.mpd?uid=546001648" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36" -H "Accept: */*" -H "Origin: https://www.cda.pl" -H "Referer: https://www.cda.pl/video/1521017489/vfilm" --key 30323861366531373232363138353865:33633361636663373 236313933353439 --use-shaka-packager -M format=mkv
    https://forum.videohelp.com/attachment.php?attachmentid=83878&stc=1&d=1733253179
    https://forum.videohelp.com/attachment.php?attachmentid=83879&stc=1&d=1733253275
    https://forum.videohelp.com/attachment.php?attachmentid=83880&stc=1&d=1733253326
    https://forum.videohelp.com/attachment.php?attachmentid=83881&stc=1&d=1733253379
    Where did I go wrong? why didn't it download ?????
    try again without shaka packager and see if it'll download.
  3. Originally Posted by october262 View Post
    I am testing mp4 now
  4. [PL]
    Zainstaluj sobie narzędzie Widevineproxy2 na przeglądarce EDGE do pobierania dla cda.pl
    Dlaczego Edge - a nie inne ? Ponieważ na EDGE - wyświetli ci link MPD H264 - a na innych przeglądarkach VP9 - co jest trudniejsze w pobraniu i rozkodowaniu.
    Przed załadowaniem rozszerzenia do przeglądarki - w pasku przeglądarki edge wpisz : edge://flags/ i przejdź na poniższy adres -
    Następnie wyszukaj :
    Playready - Disabled / Widevine - Enabled
    Dane wyciągnięte przez narzędzie Widevineproxy2 - z użyciem EDGE :
    N_m3u8DL-RE "https://vcze180.cda.pl/15210174/15210174.mpd?uid=588240021" -H "Accept: */*" -H "Origin: https://www.cda.pl" -H "Referer: https://www.cda.pl/video/1521017489/vfilm" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36 Edg/131.0.0.0" --key 30323861366531373232363138353865:33633361636663373236313933353439 --use-shaka-packager -M format=mkv
    [ENG] Install the Widevineproxy2 tool on your EDGE browser to download for cda.pl
    Why Edge - and not others? Because on EDGE - it will show you the MPD H264 link - and on other browsers VP9 - which is more difficult to download and decode.
    Before loading the extension to your browser - in the edge browser bar type: edge://flags/ and go to the address below -
    Then search for:
    Data extracted by Widevineproxy2 tool - using EDGE:
  5. thanks for your help "Kadio"
    But this link can be downloaded and is it from edge ???
  6. C:\Users\henryk\Downloads\N_m3u8DL-RE_Beta_win-x64_20240828\N_m3u8DL-RE_Beta_win-x64>N_m3u8DL-RE "https://vcze180.cda.pl/15210174/15210174.mpd?uid=588240021" -H "Accept: */*" -H "Origin: https://www.cda.pl" -H "Referer: https://www.cda.pl/video/1521017489/vfilm" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36 Edg/131.0.0.0" --key 30323861366531373232363138353865:33633361636663373 236313933353439 --use-shaka-packager -M format=mkv
    Unrecognized command or argument '236313933353439'.
    Description:
    N_m3u8DL-RE (Beta version) 20240630
    Usage:
    N_m3u8DL-RE <input> [options]
    Arguments:
    <input> Input Url or File
    Options:
    --tmp-dir <tmp-dir> Set temporary file directory
    --save-dir <save-dir> Set output directory
    --save-name <save-name> Set output filename
    --base-url <base-url> Set BaseURL
    --thread-count <number> Set download thread count [default: 4]
    --download-retry-count <number> The number of retries when download segment error [default: 3]
    --force-ansi-console Force assuming the terminal is ANSI-compatible and interactive
    --no-ansi-color Remove ANSI colors
    --auto-select Automatically selects the best tracks of all types [default: False]
    --skip-merge Skip segments merge [default: False]
    --skip-download Skip download [default: False]
    --check-segments-count Check if the actual number of segments downloaded matches the expected
    number [default: True]
    --binary-merge Binary merge [default: False]
    --use-ffmpeg-concat-demuxer When merging with ffmpeg, use the concat demuxer instead of the concat
    protocol [default: False]
    --del-after-done Delete temporary files when done [default: True]
    --no-date-info Date information is not written during muxing [default: False]
    --no-log Disable log file output [default: False]
    --write-meta-json Write meta json after parsed [default: True]
    --append-url-params Add Params of input Url to segments, useful for some websites, such as
    kakao.com [default: False]
    -mt, --concurrent-download Concurrently download the selected audio, video and subtitles [default:
    False]
    -H, --header <header> Pass custom header(s) to server, Example:
    -H "Cookie: mycookie" -H "User-Agent: iOS"
    --sub-only Select only subtitle tracks [default: False]
    --sub-format <SRT|VTT> Subtitle output format [default: SRT]
    --auto-subtitle-fix Automatically fix subtitles [default: True]
    --ffmpeg-binary-path <PATH> Full path to the ffmpeg binary, like C:\Tools\ffmpeg.exe
    --log-level <DEBUG|ERROR|INFO|OFF|WARN> Set log level [default: INFO]
    --ui-language <en-US|zh-CN|zh-TW> Set UI language
    --urlprocessor-args <urlprocessor-args> Give these arguments to the URL Processors.
    --key <key> Pass decryption key(s) to mp4decrypt/shaka-packager. format:
    --key KID1:KEY1 --key KID2:KEY2
    --key-text-file <key-text-file> Set the kid-key file, the program will search the KEY with KID from the
    file.(Very large file are not recommended)
    --decryption-binary-path <PATH> Full path to the tool used for MP4 decryption, like C:\Tools\mp4decrypt.exe
    --use-shaka-packager Use shaka-packager instead of mp4decrypt to decrypt [default: False]
    --mp4-real-time-decryption Decrypt MP4 segments in real time [default: False]
    -R, --max-speed <SPEED> Set speed limit, Mbps or Kbps, for example: 15M 100K.
    -M, --mux-after-done <OPTIONS> When all works is done, try to mux the downloaded streams. Use "--morehelp
    mux-after-done" for more details
    --custom-hls-method <METHOD> Set HLS encryption method
    (AES_128|AES_128_ECB|CENC|CHACHA20|NONE|SAMPLE_AES |SAMPLE_AES_CTR|UNKNOWN)
    --custom-hls-key <FILE|HEX|BASE64> Set the HLS decryption key. Can be file, HEX or Base64
    --custom-hls-iv <FILE|HEX|BASE64> Set the HLS decryption iv. Can be file, HEX or Base64
    --use-system-proxy Use system default proxy [default: True]
    --custom-proxy <URL> Set web request proxy, like http://127.0.0.1:8888
    --custom-range <RANGE> Download only part of the segments. Use "--morehelp custom-range" for more
    details
    --task-start-at <yyyyMMddHHmmss> Task execution will not start before this time
    --live-perform-as-vod Download live streams as vod [default: False]
    --live-real-time-merge Real-time merge into file when recording live [default: False]
    --live-keep-segments Keep segments when recording a live (liveRealTimeMerge enabled) [default:
    True]
    --live-pipe-mux Real-time muxing to TS file through pipeline + ffmpeg (liveRealTimeMerge
    enabled) [default: False]
    --live-fix-vtt-by-audio Correct VTT sub by reading the start time of the audio file [default: False]
    --live-record-limit <HH:mms> Recording time limit when recording live
    --live-wait-time <SEC> Manually set the live playlist refresh interval
    --live-take-count <NUM> Manually set the number of segments downloaded for the first time when
    recording live [default: 16]
    --mux-import <OPTIONS> When MuxAfterDone enabled, allow to import local media files. Use
    "--morehelp mux-import" for more details
    -sv, --select-video <OPTIONS> Select video streams by regular expressions. Use "--morehelp select-video"
    for more details
    -sa, --select-audio <OPTIONS> Select audio streams by regular expressions. Use "--morehelp select-audio"
    for more details
    -ss, --select-subtitle <OPTIONS> Select subtitle streams by regular expressions. Use "--morehelp
    select-subtitle" for more details
    -dv, --drop-video <OPTIONS> Drop video streams by regular expressions.
    -da, --drop-audio <OPTIONS> Drop audio streams by regular expressions.
    -ds, --drop-subtitle <OPTIONS> Drop subtitle streams by regular expressions.
    --ad-keyword <REG> Set URL keywords (regular expressions) for AD segments
    --morehelp <OPTION> Set more help info about one option
    --version Show version information
    -?, -h, --help Show help and usage information
    Dec 2021
    england
    look in your key, there is a gap space
    [Attachment 83889 - Click to enlarge]
  8. Originally Posted by iamghost View Post
    Hello iamghost
    How you did it, I am full of admiration for your cleverness, I have been struggling with this for hours.
  9. it downloaded everything but the video was distorted
    https://forum.videohelp.com/attachment.php?attachmentid=83892&stc=1&d=1733270959
    your link is different from mine and it's very different. I downloaded it from the script "WidevineProxy2"
Name:	Zrzut ekranu (24).png
  10. I applaud everyone with the nerves and patience to explain to Henryk69
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  11. Originally Posted by [ss]vegeta View Post
    See that even 2nHxWW6GkN1l9 said that the case between n_m3u8dl-re and vp9 is not that simple ,
    But if you know how to do it in a simple way, then show me.
  12. VP9 :
    Create a folder on your desktop, download and extract the files from this link to the folder:
    https://gofile.io/d/GxIbRK
    Use this command :
    N_m3u8DL-RE.exe --use-shaka-packager "https://vcze180.cda.pl/15210174vp9/15210174.mpd" --key 30323861366531373232363138353865:33633361636663373236313933353439 -M format=mp4
    [Attachment 83905 - Click to enlarge]
  13. What a great post from "Kadio", fast, specific and concise, for which I thank you very, very much
  14. It works, it works, it works "Kardio" you are great - and here I learned:
    1.N_m3u8DL-RE - old version
    2.shaka-packager.exe - what they sent me did not work at all, that's why there are glitches during playback of the film.
    We need people like Kardio in our forum, and I have been fighting with this for 3 weeks.
    Thanks again Kardio and I wish you good health
  15. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    MPD H264 can be obtained in the browser: Iridium browser, Microsoft Edge (Windows) / Mozilla Firefox (Linux). In other cases, the video loads from mpd webp.
    Did you try to set "media.webm.enabled" and "media.av1.enabled" parameters to "false" in the Firefox "about:config" page? For the Chrome-based browsers there is an addon named "h264ify/enhanced-h264ify", but it works only on YouTube service, would be better to find similar addon for any video service, maybe someone knows about it?
  16. Originally Posted by Henryk69 View Post
    PM me, i have questions about cda, im also from Poland.
  17. Originally Posted by jojkowski View Post
    You can also write to me, I will help you as much as I can
  18. this can give the mp4 dash mpd: manifest_cast
    from urllib.parse import unquote
    import requests
    import json
    import re
    resp = requests.get(link, cookies=cookies, headers=headers).text
    get_json = re.findall(r"player_data='({.*})'", resp)[0].strip()
    get_vid_json = json.loads(get_json)
    orig_title = get_vid_json['video']['title']
    title = unquote(orig_title)
    print(title)
    mpd = get_vid_json['video']['manifest_cast']
    print(mpd)
  19. unless you need to download 4k video from cda.pl you can simply use yt-dlp. it bypasses drm using mobile app api when you use provide login and password
  20. Originally Posted by monk87 View Post
    Thanks Monk87 !!!
    Aug 2018
    Wrocław
    Yes, I do that now and I can confirm it still works.
  22. If anyone needs it, I'm sharing the script.
    Simply enter your login credentials into the script and save it as a bat file. (xxxxxxxxxxxxxxxxxxxxx – replace with your appropriate credentials)
    Run the bat file, paste the URL, select the quality, and that's it.
    4K file downloads via the API are not supported – max 1080p
    title cda downloader
    REM --- Set login details ---
    set USERNAME=xxxxxxxxxxxxxxxxxxxxx
    set PASSWORD=xxxxxxxxxxxxxxxxxxxx
    echo Enter the video URL:
    set /p URL=
    echo.
    echo =============================
    echo CHOOSE QUALITY
    echo [1] Best quality (default)
    echo [2] 1080p
    echo [3] 720p
    echo [4] 480p
    echo [5] 360p
    set /p QUALITY_CHOICE=Your choice (1-5):
    REM --- Setting the format parameter ---
    if "%QUALITY_CHOICE%"=="1" set FORMAT=bestvideo+bestaudio/best
    if "%QUALITY_CHOICE%"=="2" set FORMAT="bestvideo[height<=1080]+bestaudio/best[height<=1080]"
    if "%QUALITY_CHOICE%"=="3" set FORMAT="bestvideo[height<=720]+bestaudio/best[height<=720]"
    if "%QUALITY_CHOICE%"=="4" set FORMAT="bestvideo[height<=480]+bestaudio/best[height<=480]"
    if "%QUALITY_CHOICE%"=="5" set FORMAT="bestvideo[height<=360]+bestaudio/best[height<=360]"
    REM If something else is selected - default quality
    if not defined FORMAT set FORMAT=bestvideo+bestaudio/best
    echo.
    echo I check the Downloads folder...
    REM --- Automatic Downloads folder next to the file .bat ---
    set SAVEFOLDER=%~dp0Downloads
    REM --- Checking if a folder exists ---
    if exist "%SAVEFOLDER%" (
    echo Folder Downloads it already exists – I use it.
    ) else (
    echo Creating a Downloads folder...
    mkdir "%SAVEFOLDER%"
    echo The folder has been created.
    echo Save folder: %SAVEFOLDER%
    echo.
    echo.
    echo START DOWNLOADING
    yt-dlp.exe -u "%USERNAME%" -p "%PASSWORD%" ^
    -f %FORMAT% ^
    -o "%SAVEFOLDER%\%%(title)s.%%(ext)s" ^
    "%URL%"
    echo.
    echo COMPLETED
    pause
  23. Member
    Sep 2022
    This is great.
    Thanks brother
  24. super kardio
