Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 87
  1. I will write what actions I performed:
    1) First, I copied the folder with all the contents called "pywidevine" from the WKS-KEY folder to the folder "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\
    2) From the android_generic folder I copied 2 files named: device_private_key , and device_client_id_blob
    3) Then I wanted to create a WVD file by running on the command line:
    pywidevine create-device -k "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\pywidevine\device_private_key" -c "C:\Users\UserName\AppData\Local\Programs\ Python\Python312\Lib\site-packages\pywidevine\device_client_id_blob" -t "ANDROID" -l 3 -o "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\WVD"
    4) I received the message:
    "Traceback (most recent call last):
    File "<frozen runpy>", line 198, in _run_module_as_main
    File "<frozen runpy>", line 88, in _run_code
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Scripts\pywidevine.exe\__main__.py", line 4, in <module>
    ModuleNotFoundError: No module named 'pywidevine.main'
    5) Please help for which I thank you in advance.
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Yeah, you're doing it entirely wrong. You don't use an existing pywidevine from I dunno where, you install it fresh using pip install.
    https://pypi.org/project/pywidevine/
    Delete the old one from where you copied and install new.
  3. Bad news again, I don't know what to do ://
    INFO:rootywidevine version 1.8.0 Copyright (c) 2022-2024 rlaphoenix
    INFO:root:https://github.com/devine-dl/pywidevine
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Scripts\pywidevine.exe\__main__.py", line 7, in <module>
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\click\core.py", line 1157, in __call__
    return self.main(*args, **kwargs)
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\click\core.py", line 1078, in main
    rv = self.invoke(ctx)
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\click\core.py", line 1688, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\click\core.py", line 1434, in invoke
    return ctx.invoke(self.callback, **ctx.params)
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\click\core.py", line 783, in invoke
    return __callback(*args, **kwargs)
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\click\decorators.py", line 33, in new_func
    return f(get_current_context(), *args, **kwargs)
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\pywidevine\main.py", line 197, in create_device
    device = Device(
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\pywidevine\device.py", line 108, in __init__
    self.private_key = RSA.importKey(private_key)
    File "C:\Users\UserName\AppData\Local\Programs\Python\P ython312\Lib\site-packages\Crypto\PublicKey\RSA.py", line 853, in import_key
    raise ValueError("RSA key format is not supported")
    ValueError: RSA key format is not supported
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Dump your own CDM and try with those. All the steps are detailed on the stickies.
  5. Thank you for help, unfortunately, I have another problem and questions,
    In your code "
    WVD_FILE = "device_wvd_file.wvd" "should I give the path or just the file name? Should I change the name of this file to e.g. "google google_android_sdk_built_for_x86_v4.1.0-android_xxxxxxxx_xxxx_l3.wvd" i.e. the one that was generated? Because unfortunately I have problems again :/ thanks for answer.
    Where should the .wvd file be placed?
  6. With a lot of help from 2nHxWW6GkN1l916N3ayz8HQoi I did some important things, but I managed to get something that is close to the final solution, i.e. I got PSSH, License URL, Manifest, link to .MPD file ,but unfortunately I get an error:
    File "C:\Users\UserName\Downloads\DRM-xxxxx\DRM\CDA.py", line 141, in <module>
    print(get_download_command(s))
    File "C:\Users\UserName\\Downloads\DRM-xxxxx\DRM\CDA.py", line 124, in get_download_command
    keys = get_keys(pssh, license_url, custom_data)
    File "C:\Users\UserName\\Downloads\DRM-xxxxx\DRM\CDA.py", line 81, in get_keys
    license.raise_for_status()
    File "C:\Users\UserName\\AppData\Local\Programs\Python\ Python312\Lib\site-packages\requests\models.py", line 1021, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
    requests.exceptions.HTTPError: 406 Client Error: for url: https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
    I am very close to the solution, but please tell me what may cause the above errors and how to fix it, thanks again!
  7. Member aqzs's Avatar
    Mar 2024
    Paris
    In your code "
    place the .wvd file in the same directory as the python script, rename it to device.wvd and in the script put 'devide.wvd' : device = Device.load(r"device.wvd")
    Mar 2024
    Poland
    I'm trying to use the script and I have the following information:
    C:\Users\grzech67>python D:\CDA\cda.py
    Need local CDM (in WVD format) for https://www.cda.pl/video/1670572f2/vfilm
    Need local CDM (in WVD format) for https://www.cda.pl/video/250188864/vfilm
    Need local CDM (in WVD format) for https://www.cda.pl/video/2508939fb/vfilm
    Need local CDM (in WVD format) for https://www.cda.pl/video/161441361/vfilm
    Need local CDM (in WVD format) for https://www.cda.pl/video/153780264/vfilm
    What am I doing wrong ?
  9. Member aqzs's Avatar
    Mar 2024
    Paris
    If you named your CDM 'device.wvd' and placed it in the python code as 'device.wvd', then from the directory where you run the script you have to place the CDM.
    You should have something like that :
    device.wvd, cda.py in the same folder, open a cmd in this folder and run : python cda.py
  10. psaframe
    Mar 2021
    Algeria
    Need local CDM
    you have to set wvd file in path bro
  11. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Here is a downloader for https://www.cda.pl . It works only for free DRM content. No account needed. Only Polish IP.
    import html
    import json
    import re
    import requests
    from cf_clearance import sync_cf_retry, sync_stealth
    from playwright.sync_api import sync_playwright
    from pywidevine.cdm import Cdm
    from pywidevine.device import Device
    from pywidevine.pssh import PSSH
    MAIN_URL = "https://www.cda.pl"
    CF_RETRIES = 8
    def bypass_cloudflare():
        user_agent, cf_clearance = None, None
        retry = 0
        failure = False
        with sync_playwright() as spw:
            browser = spw.firefox.launch(headless=True)
            page = browser.new_page()
            sync_stealth(page)
            page.goto(MAIN_URL)
            while True:
                if sync_cf_retry(page):
                    for cookie in page.context.cookies():
                        if cookie.get('name') == 'cf_clearance':
                            cf_clearance = cookie.get('value')
                            break
                    user_agent = page.evaluate('() => {return navigator.userAgent}')
                    if cf_clearance is not None:
                        break
                else:
                    retry = CF_RETRIES
                retry += 1
                if retry >= CF_RETRIES:
                    failure = True
                    break
            browser.close()
        if failure:
            print("Failed to bypass cloudflare")
            exit(0)
        return user_agent, cf_clearance
    def check_cloudflare():
        if "Just a moment..." in requests.get(MAIN_URL).content.decode():
            user_agent, cf_clearance = bypass_cloudflare()
            return {"User-Agent": user_agent, "cf_clearance": cf_clearance}
        return {"User-Agent": None, "cf_clearance": None}
    CLOUDFLARE = check_cloudflare()
    def get_keys(pssh_value, license_url, custom_data):
        if pssh_value is None:
            return []
        try:
            device = Device.load(WVD_FILE)
        except:
            return []
        pssh_value = PSSH(pssh_value)
        cdm = Cdm.from_device(device)
        cdm_session_id = cdm.open()
        challenge = cdm.get_license_challenge(cdm_session_id, pssh_value)
        licence = requests.post(
            license_url, data=challenge,
            headers={'x-dt-custom-data': custom_data}
        licence.raise_for_status()
        cdm.parse_license(cdm_session_id, licence.content)
        keys = []
        for key in cdm.get_keys(cdm_session_id):
            if "CONTENT" in key.type:
                keys += [f"{key.kid.hex}:{key.key.hex()}"]
        cdm.close(cdm_session_id)
        return keys
    def get_video_data(source_url):
        response = requests.get(
            source_url, cookies={'cf_clearance': CLOUDFLARE['cf_clearance']},
            headers={'User-Agent': CLOUDFLARE['User-Agent']}
        ).content.decode()
        if "player_data" not in response:
            print("VPN error")
            exit(0)
        content = json.loads(html.unescape(re.findall(
            r'player_data="([^"]*)"',
            response
        )[0]))["video"]
        manifest = content["manifest"]
        license_url = content["manifest_drm_proxy"]
        custom_data = content["manifest_drm_header"]
        try:
            pssh_value = str(min(re.findall(
                r'<cenc:pssh\b[^>]*>(.*?)</cenc:pssh>',
                requests.get(manifest).content.decode()
            ), key=len))
        except:
            return manifest, None, None, None
        return manifest, pssh_value, license_url, custom_data
    def get_download_command(source_url):
        manifest, pssh, license_url, custom_data = get_video_data(source_url)
        if manifest is None:
            return f"No manifest found for {source_url}"
        if len(keys) == 0:
            if pssh is not None:
                return f"Need local CDM (in WVD format) for {source_url}"
            return f'N_m3u8DL-RE.exe "{manifest}" -M format=mkv'
        return f'N_m3u8DL-RE.exe "{manifest}" {" ".join([f"--key {k}" for k in keys])} -M format=mkv'
    SOURCE_URLS = [
        "https://www.cda.pl/video/1670572f2/vfilm",
        "https://www.cda.pl/video/250188864/vfilm",
        "https://www.cda.pl/video/2508939fb/vfilm",
        "https://www.cda.pl/video/161441361/vfilm",
        "https://www.cda.pl/video/153780264/vfilm",
    for s in SOURCE_URLS:
    Output:
    N_m3u8DL-RE.exe "https://vcze133.cda.pl/1670572/1670572.mpd" --key 65393535653839613762613264653965:61313762326463356164353236313733 -M format=mkv
    N_m3u8DL-RE.exe "https://vcze132.cda.pl/2501888/2501888.mpd" --key 61613231316161643435373634633964:66373332396336306463303230643834 -M format=mkv
    N_m3u8DL-RE.exe "https://vcze134.cda.pl/2508939/2508939.mpd" --key 31323139303536666134663734373337:66656633633631623466396665636334 -M format=mkv
    N_m3u8DL-RE.exe "https://vcze804.cda.pl/1614413/1614413.mpd" --key 33646461333363393134353838643932:35623262336231363562663331356237 -M format=mkv
    N_m3u8DL-RE.exe "https://vcze801.cda.pl/1537802/1537802.mpd" --key 33356535653566373663643734313536:30313135616230306632306139643832 -M format=mkv
    The download command can be used without a VPN to avoid wasting data. The site uses Cloudflare protection but that can be bypassed by generating a cf_clearance cookie using an automated browser. The non-DRM content can be easily downloaded by looking at the network requests for a mp4 file.
    What browser did you use to extract the mpd links?
    In most browsers I have an mpd vp9 link - where I download files in webp format - which is useless.
  12. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    If the script is not working for a specific case, provide the URL you are attempting. I have no idea what you're asking me.
  13. Many thanks !!! to 2nHxWW6GkN1l916N3ayz8HQoi for his kind help! , brilliant script that works perfectly.
    I have a question, is it possible to use the website https://cdrm-project.com/ , having PSSH, license URL, headers, custom data obtaining keys without your own CDM ( Free DRM content from CDA.PL ) ?
  14. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    is it possible to use the website https://cdrm-project.com/ , having PSSH, license URL, headers, custom data obtaining keys without your own CDM?
    Yes, it is possible. But out of principle, I won't add "magical" external APIs that make the job easier for the end-user. There will be more points where stuff could break unexpectedly and also people won't even care how to dump a CDM anymore, so I won't do that. If anyone else wants to modify this script to add that, then feel free to do it.
  15. Thanks for the detailed explanations!
  16. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    MPD H264 can be obtained in the browser: Iridium browser, Microsoft Edge (Windows) / Mozilla Firefox (Linux). In other cases, the video loads from mpd webp.
    Movies : https://www.cda.pl/video/18723067d0/vfilm
    MPD H264 : https://vcze190.cda.pl/18723067/18723067.mpd - obtained from Microsoft edge
    MPD WEBP (vp9) : https://vcze190.cda.pl/18723067vp9/18723067.mpd - obtained from Google chrome
    Supposedly the same movie, but different MPD - depending on the browser or operating system.
    Webp is more difficult to decrypt, connect and recreate.
  17. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    If you take a look at the script you'll notice this line
    So I'm using firefox.
  18. Member
    Sep 2024
    TX, USA
    How about this movie?
    https://www.cda.pl/video/32591265d
    I've tried extracting to no avail
  19. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Open network requests. Filter for mp4. Select 720p quality. Take last request and copy the URL in a new tab. Right click save as video. It doesn't even use DRM.
    Edit: I checked yt-dlp also. It works directly with that as well
    yt-dlp "https://www.cda.pl/video/32591265d"
  20. Member aqzs's Avatar
    Mar 2024
    Paris
    https://vwaw673.cda.pl/h/b/b/24/na/20ANhamYK_FG0QpODIdbEA/33/1725609394/sd23d4893f304f266834ea3749e66d248ac3c1321f2d28547f285cc5c306fc7700.mp4
    https://gofile.io/d/8FMFs0
    Sep 2024
    TX, USA
    Thank you! That worked
  22. Member
    Aug 2018
    Wrocław
    Originally Posted by white_snake View Post
    Originally Posted by rgr View Post
    Wow, great job.
    But how to use this script?
    Save this script in a text file and name it cdapl.py, install python (select option to add it to PATH), open your command prompt, run
    python cdapl.py
    Thanks, but an error appears at the beginning.
    C:\_from www\cda>python cda.py
      File "C:\_from www\cda\cda.py", line 5, in <module>
        import requests
    ModuleNotFoundError: No module named 'requests'
    Python 3.12 installed.
    Path:
    PATH=[...]c:\program files\python312\scripts\;c:\program files\python312\ [...]
  23. Banned
    Jun 2024
    Wow, great job.
    python cdapl.py
        import requests
    Path:
    pip install requests
  24. Member
    Aug 2018
    Wrocław
    Wow, great job.
    python cdapl.py
        import requests
    Path:
    c:\cda>python cda.py https://www.cda.pl/video/170417420d
    VPN error
  25. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    That script is outdated and also meant only for DRM videos. If you want a newer and maintained version use
    python widefrog.py "https://www.cda.pl/video/170417420d"
    Otherwise, since it's not DRM, just filter for mp4 and take the URL to download it from network requests.
  26. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    yeah or use yt-dlp for this
  27. Member
    Aug 2018
    Wrocław
    Yes, I forgot that yt-dlp works
  28. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Is it possible to download such a file?
    DRM + fragmentation
    https://www.cda.pl/video/1670449e2/vfilm
    N_m3u8DL-RE.exe https://vcze131.cda.pl/1670449/1670449.mpd --key 65353534306438366535346135346161:39303439626631336363393537303934 -M format=mkv
    Here's your movie (apparently it's just the first part of 4): https://www.transfernow.net/dl/20240226Acbs3b9g
    Need login.
    Polish proxy
    2nHxWW6GkN1l916N3ayz8HQoi I have a request for you: I have been looking for a long time for the keys to the link from https://www.cda.pl/video/1521017489/vfilm, the ones I provide are wrong and this is my favorite movie
  29. Originally Posted by Henryk69 View Post
    DRM + fragmentation
    Need login.
    Polish proxy
    N_m3u8DL-RE "https://vcze180.cda.pl/15210174/15210174.mpd" --key 30323861366531373232363138353865:33633361636663373236313933353439 --save-name "Czuwaj_2017_Caly_film_PL" -M format=mp4
    generated with widefrog https://forum.videohelp.com/threads/414548-drm-free-content-batch-downloader-widefrog
  30. I have a link to a film from da.pl
    From Widevine Proxy2 I downloaded the command to CDM
    N_m3u8DL-RE "https://vcze180.cda.pl/15210174vp9/15210174.mpd?uid=546001648" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36" -H "Accept: */*" -H "Origin: https://www.cda.pl" -H "Referer: https://www.cda.pl/video/1521017489/vfilm" --key 30323861366531373232363138353865:33633361636663373 236313933353439 --use-shaka-packager -M format=mkv
    https://forum.videohelp.com/attachment.php?attachmentid=83878&stc=1&d=1733253179
    https://forum.videohelp.com/attachment.php?attachmentid=83879&stc=1&d=1733253275
    https://forum.videohelp.com/attachment.php?attachmentid=83880&stc=1&d=1733253326
    https://forum.videohelp.com/attachment.php?attachmentid=83881&stc=1&d=1733253379
    Where did I go wrong? why didn't it download ?????
Name:	Zrzut ekranu (20).png
Name:	Zrzut ekranu (18).png
Name:	Zrzut ekranu (17).png
Name:	Zrzut ekranu (19).png
