possible to change video Resolution 1920x1080 to 1280x720 without encoding ? and quality should same
One can use a player, such as VLC, to show in a window of various sizes on playback, so you could show a 1920x1080 clip at 1280x720, without loss due to re-encoding because it isn't re-encoding. It will of course have less visible detail, so there will be loss of "quality".
If, OTOH, you want it saved that way, you MUST re-encode.
change sourcedata/resolution
By Resol in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2022, 07:34 -
XMedia Recode forces it's own resolution, can't change it
By Lemenus in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2020, 08:08 -
What's the best way to change a video (.mkv) resolution?
By MC23 in forum Newbie / General discussionsReplies: 7Last Post: 30th Apr 2020, 13:22 -
Handbrake: Simply need to change video resolution
By WannaBeAVideoGuy in forum Video ConversionReplies: 6Last Post: 1st Dec 2019, 08:44 -
Using MyMP4Box to change resolution
By PCC in forum Video ConversionReplies: 8Last Post: 18th Mar 2019, 09:17
