Hi,
Currently I've Elgato VideoCapture but it doesn't seem good enough. Any recommendations on other options would be greatly appreciated.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
What kind of tape are you digitizing, that would help to put more infos...
This deck can transcode to any format pal,secam,ntsc, mesecam, pal-m, not your average deck... (does it do it well, i sure don't know)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Thanks guys.
Going to try VirtualDub and will share some samples of S-VHS and VHS tapes captures.
Btw, If I've to buy another capture device (as Elgato is quite old h/w) , what would you recommend? I've Linux and Window10/11 systems to use with.
Thanks -
My experience of this and the Panasonic is not the greatest actual VCR desk, its better to use well mentioned native VCR and capture natively then use software to convert. Just my experience, may be the decks I had were worn out but using decks like JVC (either pal or ntsc) with TBC.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
I had this tab open for weeks, and I had wanted to give a long reply to this, but no longer can. In short, this is a terrible VCR. The NTSC and PAL are beyond crap, and only the SECAM is passable because so few decent SECAM options exist. Maybe PAL-N, PAL-M, reluctantly.
Combined with a low-end capture card (Elgato, Easycap, Dazzle, etc), and it's a hot mess.
Win10/11 and Linux are the wrong tool for SD analog videotape capture. This is a legacy task, and legacy OS are almost always needed.Want my help? Ask here! (not via PM!)
I cannot fathom why anyone would convert pal/ntsc when there are miryiad multi dvd playersaround and mkv/mp4 don't care for playback.
White flashing in VHS capture using Elgato Video Capture.
By R3DWO1Fess01 in forum CapturingReplies: 1Last Post: 10th Dec 2023, 19:19 -
SV-5000W shuts down after play or eject
By umbada in forum CapturingReplies: 14Last Post: 15th Oct 2022, 16:23 -
Elgato Video Capture Audio Cutting In and Out During Capture
By JasonQuinn1992 in forum CapturingReplies: 7Last Post: 21st Mar 2022, 10:34 -
Using Canon's EOS Utility to capture on screen video VS a capture card
By RoyZ7 in forum CapturingReplies: 0Last Post: 23rd Apr 2020, 07:18 -
Samsung Galaxy S10 - HDR10+ video sample anyone?
By Selur in forum Off topicReplies: 3Last Post: 2nd Jun 2019, 00:28
