Results 1 to 16 of 16
  1. There are a lot of video capture devices out there. A LOT of them! Which is why I could use some suggestions.
    I posted another thread about a good VHS deck for older camcorder tapes (possibly damaged). This is about suggestions for the capture device. I believe it's in the right category.
    Essentially, what is a good "bang for the buck" device to capture NTFS video (or S-video) to a computer, for archival? No intent to put onto optical media or anything. I'll be using a vintage VHS player of some sort, and analog AV inputs. The computer will have USB 3 and is a midrange i7 laptop. Nothing remarkable in either direction.
    Naturally, a device with HDMI capture, as well, is handy, for future use, but for this project, I just want to pick an NTFS capture which will do a solid job, without worrying about unneeded fancy features.
    Thanks in advance.
  2. Banned
    Nov 2022
    I-O Data GV-USB2, but see for yourself.
    P.S. NTFS is a file system.
  3. Capturing Memories dellsam34's Avatar
    Jan 2016
    Our British funny guy did a nice hardware comparison between few USB capture devices in 3 rounds and he concluded that the Startech.com USB capture device is the best among all according to him, With generic brand easycap and clearclick being the worst and GV-USB2 and Startech.com devices being the best:
    The first round video, Second round video, Third round video (the final winner).
    Warning: Videos are too funny.
    Note: He uses OBS which is the wrong tool for capturing analog video, There are better alternatives.
  4. Banned
    Nov 2022
    He uses OBS because his main system is not Windows. He cursed several products for having either the driver or the software or both designed for Windows only. Hence, the rise of OBS
  5. Is there any devices to use to record a vhs tape without a computer what is the best devices to play a vhs tape and record to maybe a micro sd card or usb stick I have seen some items but I don’t know if they work or not has anyone used any items like this.
  6. Banned
    Nov 2022
    I have this box, which I reviewed here. I bought it for $60; as recently as half a year ago it was sold for $30, and for this money it would be a decent device. A similar, but a much more expensive box is Cloner Alliance Pro HD, which 12voltvids quite likes, but it seems to have the same issues as my box, and the only difference is that it records in 1080p60 in addition to 720p60 and 1080p30 that my box does.
  7. Thanks for the suggestions.
    Yeah.... stupid me. I typed NTFS, I meant NTSC. It's what I get for making my post after 2 AM. Heh.
    As for OBS, what are the better alternatives to it?
    Aug 2018
    Wrocław
    1. 30/60 fps (not 25/50 or 29,97/59,94)
    2. no exFAT, no NTFS
    3. no 576p or 576i
    4. records 16:9
    5. bad metainfo (no "color-range: full")
    You can't have any more flaws
    AverMedia ER-330:
    1. 50fps for PAL
    2. exFAT+NTFS
    3. 576p
    4: DAR 4:3
    5. good metainfo (records 16-235)
    6. HEVC 12mbit/s (for 576p)
  9. Banned
    Nov 2022
    Originally Posted by rgr View Post
    AverMedia ER-330:
    1. 50fps for PAL
    2. exFAT+NTFS
    3. 576p
    4: DAR 4:3
    Have you used it? Write a review or make a video! I am not going to spend $110 for a box I don't need, and I hate returning stuff.
  10. Originally Posted by rgr View Post
    AverMedia ER-330:
    1. 50fps for PAL
    2. exFAT+NTFS
    3. 576p
    4: DAR 4:3
    Just pointing out.... the ER-330 has some pretty bad reviews. Are they in error?
    Aug 2018
    Wrocław
    AverMedia ER-330:
    1. 50fps for PAL
    2. exFAT+NTFS
    3. 576p
    4: DAR 4:3
    Yes. But it's hard for me to review it because I have nothing to compare it to. It records ok, there are no major flaws (apart from the lack of recording in 576i). An interesting fact is that it records in VFR, but without a deeper analysis it is difficult to say whether it is a disadvantage or an advantage.
    It records from HDMI, and since it only has Composite, not Component, I didn't even check the analog recording.
    General
    Format                         : MPEG-4
    Format profile                 : Base Media / Version 2
    Codec ID                       : mp42 (mp42/mp41/isom/iso2)
    File size                      : 6.64 GiB
    Duration                       : 1 h 19 min
    Overall bit rate mode          : Variable
    Overall bit rate               : 12.0 Mb/s
    Frame rate                     : 50.000 FPS
    Encoded date                   : 2024-02-22 18:56:58 UTC
    Tagged date                    : 2024-02-22 20:16:06 UTC
    Video
    Format                         : HEVC
    Format/Info                    : High Efficiency Video Coding
    Format profile                 : Main@L3@Main
    Codec ID                       : hvc1
    Codec ID/Info                  : High Efficiency Video Coding
    Bit rate                       : 11.9 Mb/s
    Maximum bit rate               : 68.0 Mb/s
    Width                          : 720 pixels
    Height                         : 576 pixels
    Display aspect ratio           : 4:3
    Frame rate mode                : Variable
    Minimum frame rate             : 42.735 FPS
    Maximum frame rate             : 60.241 FPS
    Color space                    : YUV
    Chroma subsampling             : 4:2:0
    Bit depth                      : 8 bits
    Bits/(Pixel*Frame)             : 0.573
    Stream size                    : 6.57 GiB (99%)
    Color range                    : Limited
    Color primaries                : BT.601 PAL
    Transfer characteristics       : BT.601
    Matrix coefficients            : BT.470 System B/G
    Codec configuration box        : hvcC
    Audio
    Format                         : AAC LC
    Format/Info                    : Advanced Audio Codec Low Complexity
    Codec ID                       : mp4a-40-2
    Bit rate mode                  : Variable
    Bit rate                       : 125 kb/s
    Maximum bit rate               : 190 kb/s
    Channel(s)                     : 2 channels
    Channel layout                 : L R
    Sampling rate                  : 48.0 kHz
    Frame rate                     : 46.875 FPS (1024 SPF)
    Compression mode               : Lossy
    Stream size                    : 71.0 MiB (1%)
    Aug 2018
    Wrocław
    I don't know, I haven't seen any. They are probably referring to HD. I just checked - it records in 50mbit.
  13. Banned
    Nov 2022
    It's hard for me to review it because I have nothing to compare it to. It records ok, there are no major flaws (apart from the lack of recording in 576i). An interesting fact is that it records in VFR, but without a deeper analysis it is difficult to say whether it is a disadvantage or an advantage.
    General
    Format                         : MPEG-4
    Video
    Format                         : HEVC
    Codec ID                       : hvc1
    Width                          : 720 pixels
    Height                         : 576 pixels
    Color space                    : YUV
    Bit depth                      : 8 bits
    Audio
    Format                         : AAC LC
    Bit rate                       : 125 kb/s
    576p50 is neither here nor there. You can watch it on a computer, or you can make an AVCHD Disc. It does not work for a DVD, and when uploaded on YouTube it will turn into 25p - doggone YouTube! I wish they had a setting for 960x720p50 or 1440x1080p50 or, conversely, to 720x576i25.
  14. In my case, analog is exactly what I'd like to know about, since I'll be capturing from a VCR.
    What's the best capture software to use? The reviews I see suggest the included software seems to be very bad. All I care about, then, is a functional driver. I can use another program to encode and save the stream. What do you guys suggest?
    Aug 2018
    Wrocław
    I also use this to capture from VCR. Panasonic DMR-EH does the TBC and doesn't convert back to the analog signal, only output to HDMI.
    May 2005
    Australia-PAL Land
    AmarecTV is well-regarded on this forum for analogue capture. I have written a guide for it here.
    It will give you an interlaced, compressed lossless AVI file in the video codec of your choice; HUFFYUV, LAGARITH and UT video are free.
