Trying to download Fatal Flight Shoreham from Discovery Plus but having some issues, just wondering if this is actually possible. Link below:
https://www.discoveryplus.com/gb/show/fatal-flight-shoreham
Results 1 to 11 of 11
Decryption Keys:
1c5e46969fd7401aadcc978a6281fb9a:d22e38c6898374d53 6ac82c168ff6312 -
Have you tried using The Stream Detector browser extension? That should make it pretty easy for everyone.
I'll use that moving forward thank you, just noticed i cant get the MPD as my pass expired last week will have to keep an eye out for another trial cropping up to grab the link etc. again. Thanks for that though as it should make it easier next time round
Can anyone enlighten me of the method for dealing with the video/audio out of sync issues caused by the removal of the ads ?
from my experience, when you cut video portion, the part of the video and its audio are removed. then the remaining video stays in sync
explain better what you mean -
It's not like that on some sites, the subs have timings for each line of subtitle text to match the programme stream including adverts. So, say, for 240 seconds during adverts no subtitles play So at the end first ad-break, which gets cut away, the subtitles have times to start again 240 seconds out of sync
I found this on STV.tv when I was experimenting cutting adverts included in the video stream using boltdns.net SSAI (Server Side Advert Inclusion) technology. Thankfully they stopped using SSAI. I could cut adverts precisely given they supplied timings to 1/100 sec but subs always became out of sync.
I couldn't see an easy way around it by code
You may find playing your stream through VLC on Android TV allows a version of VLC that has the facility to use a web-library of subtitles which can be downloaded. I've used a few with great success and a few that frustrate me no end. You need to find the right verion for your video.
Or, if you have time, search for the source of the subtitle-library on the web and combine a downloaded sub onto your video stream with ffmpeg.Noob Starter Pack. Just download any Widevine media! Over 25,000 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
yes, you're right about subs. but the user above (post#6) talk only about video/audio
cause this i've ask him to explain better his issue -
PlutoTV had lip sync issues and stabbedbybrick addressed it in his Freevine PlutoTV service. I was the one who brought up the issue and thankfully he figured out the remedy.
A download issue [discovery+]
By CrymanChen in forum Video Streaming DownloadingReplies: 34Last Post: 31st Dec 2022, 10:39 -
Help dl a vid from Discovery
By fosman in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Dec 2022, 07:51 -
Discovery Plus
By Willow5 in forum Video Streaming DownloadingReplies: 24Last Post: 14th Sep 2022, 18:10 -
Downloading from Discovery.ca (Canada)
By Hishighness420 in forum Video Streaming DownloadingReplies: 1Last Post: 28th Jul 2020, 17:52 -
Downloading video from discovery.ca
By flinch987 in forum Video Streaming DownloadingReplies: 5Last Post: 26th Jan 2020, 13:27
