Hello,
I need a curl command to extract m3u8 URL from below website:
https://rotana.net/en/channels?tz=-180/channels#/live/rotana_Clip
The resulting URL will be something like this:
https://rotananet.hibridcdn.net/rotana/clip_abr/rotana/clip_720p/chunks.m3u8?p=48&s=17...6ebf28a104f83f
Please note that the parameters "e", "s", "cf" and "h" will change on each page reload.
Thanks in advance.
Curl bash
Output:Code:id="rotana_Clip"; curl -s "https://rotana.net/en/channels?tz=-180/channels#/live/$id" | grep -oE "<[^>]* id=\"$id\"[^>]*https?://[^'\'']*" | grep -oE 'https?://[^'\''"]+' | xargs -I {} curl -s "{}?_=$(date +%s)" | grep -oP "(?<=o=\[)[^\]]+(?=])" | tr -d "'," | base64 -d | grep -o '"streamUrl":\s*"[^"]*"' | awk -F '"' '{print $4}'
Edit: And here's the command if you want the best resolution m3u8:Code:https://hiplayer.hibridcdn.net/p/rotana-clip?p=48&s=1708628259&e=1708714659&cf=1708714659&h=160e4e940d53bcff6abff6d484fcf7b4
Output:Code:id="rotana_Clip"; curl -s "https://rotana.net/en/channels?tz=-180/channels#/live/$id" | grep -oE "<[^>]* id=\"$id\"[^>]*https?://[^'\'']*" | grep -oE 'https?://[^'\''"]+' | xargs -I {} curl -s "{}?_=$(date +%s)" | grep -oP "(?<=o=\[)[^\]]+(?=])" | tr -d "'," | base64 -d | grep -o '"streamUrl":\s*"[^"]*"' | awk -F '"' '{print $4}' | xargs -I {} curl -s {} | grep -oE 'https?://[^ ]*' | tail -1
Code:https://rotananet.hibridcdn.net/rotana/clip_abr/rotana/clip_1080p/chunks.m3u8?p=48&s=1708628259&e=1708714659&cf=1708714659&h=160e4e940d53bcff6abff6d484fcf7b4
How to merge video m3u8 url and audio m3u8 url live channel
By sairaj in forum DVB / IPTVReplies: 2Last Post: 3rd Jul 2023, 07:29 -
Need curl command to extract m3u8 from live TV website
By tonygables in forum Video Streaming DownloadingReplies: 5Last Post: 25th Apr 2023, 06:10 -
How to automatically extract the m3u8 stream URL from this site?
By BosseB in forum Video Streaming DownloadingReplies: 23Last Post: 7th Feb 2023, 21:13 -
How to automatically extract m3u8 URL from this streaming site?
By BosseB in forum Video Streaming DownloadingReplies: 12Last Post: 10th Oct 2022, 08:10 -
How to extract and use an m3u8 URL to download from a 24/7 stream?
By BosseB in forum Video Streaming DownloadingReplies: 28Last Post: 1st Feb 2022, 08:57
