Ive got this MPEG and i would like to add some text to the frames like 'encoded by lukey' or woteva wot program can do this! and im loookn for freeware
You can add your text to clips using VirtualDub and its subtitler filter. You can also add images using the Logo filter. This is applicable only for MPEG 1.
A word of Warning, that since your source is MPEG, you will need to reencode and this will result in a poorer quality. I would advise you to work on the original source if possible.
Some help needed with multiAVCHD
By VOYAGER2009 in forum Authoring (DVD)Replies: 6Last Post: 20th Jul 2011, 11:19 -
YAAI help needed
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2011, 05:18 -
AviSynth much needed help!
By dbanimal in forum EditingReplies: 18Last Post: 28th Jan 2011, 10:33 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
