  1. Ive followed the instructions and added the stream detector copied the url in stream detector as table
    [Attachment 77176 - Click to enlarge]
    Then I get an error message saying
    [info] Use Stream Detector "copy as Table Entry"
    Enter TSD Table Entry: https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/3047407010001/8...AxMzE5OQ%3D%3D
    ___ _________ ___ _ __ _______ __
    / _ |/ ___/ __ \/ _ \/ |/ / /_ __/ | / /
    / __ / /__/ /_/ / , _/ / / / | |/ /
    /_/ |_\___/\____/_/|_/_/|_/ /_/ |___/
    ▁▁▁▁▁▁▁▁▁▁▁▁▁▁▁▁ An Acorn TV batch downloader ▁▁▁▁▁▁▁▁▁▁▁▁▁▁▁▁
    File "C:\Acorn\WKS-KEYS\acorn.py", line 300, in <module>
    videoname1 = linetuple[1]
    IndexError: list index out of range
    PS C:\Acorn\WKS-KEYS>
    Any idea whats wrong please
    https://uk.acorn.tv/mrssidhuinvestigates/series1/ripped/
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Link to video?
    Dec 2021
    england
    --key b4651140dd7044229c96c6b587946060:610c18066e52a0f446ef9317ac882bb9
  4. I can find the keys cant get the script to work correctly wondered what the error is
  5. Originally Posted by PSXman_uk View Post
    Where did you get acorn.py from?
    It's probably outdated.
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  6. From
    # v 4.4
    # A_n_g_e_l_a 26:07:2023
    The Dungeon of Despair
    Feb 2022
    Search the forum first!
    Yes. Operator error.
    You were asked for a Table Entry yet you provided only the mpd. Configure The Stream Detector to return a Table-Entry and re-try.
    I haven't used that script since using it as an example but it was standard boltdnsnet stuff and they pass keys as easily as COVID passes the virus!
    EDIT. I've just run that script to check and the remote CDM at https://wvclone.fly.dev/wv, appears to be dead so use your own CDM and set REMOTE = False where once it was True - few lines down from the top of the script.
    [Attachment 77183 - Click to enlarge]
    Note how my Table Entry has a programme title following the mpd? That becomes linetuple[1]!
    Noob Starter Pack. Just download any Widevine media! Over 31,500 downloads for V6!.
    Feb 2024
    Spain
    I found the pssh and license. What will be the header?
