Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
  1. Hi Chaps,....
    I am having trouble getting the 1080p stream from https://ww1.m4uhd.tv/watch-movie-the-debt-collector-1999-260801.html
    There are 3 streams available but only one has the 1080p.
    And for some reason or another "Stream Detector" just will not work on it. I have tried using the latest version of firefox and chrome.
    Cococut does not see it either. MPD detector will not see it, and any form of "developer tools" blocks and stops the stream. Is there an alternative to stream detector that I am not aware of?? or a possible fork, seeing as it's not been updated for ages. any help would be really helpful chaps.
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    I think only Hydrax (H) has the 1080p version, right? Hydrax uses websockets, so no m3u8 there.
  3. If you choose #backup, Stream Detector detects m3u8
    But only 640x360 | 720 Kbps
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Yep. Hydrax. A bit tricky but it can still be downloaded. Here's your 1080p video.
    https://www.transfernow.net/dl/20240221IxGjpdwZ
    Funnily, the subtitles from the first source seem more tricky to download. That is if they are subtitles and not captions.
    Edit: Seems it's just a srt. Link: https://api.playhq.net/sub?url=https://sub.ourmovie.net/sub/sub/1b2f589c4dddbc6bc6c153a6e44c2260.srt
  5. Thanks for replying chaps, Yes,... i found that it's abyss.to that holds the 1080p stream. So I'm guessing does that mean that it's hydrax (was that the name before it became abyss)??
    Much appreciated for the d/l link 2nHxWW6GkN1l916N3ayz8HQoi.
    I'd really like to find out how you managed to get around this problem. I've searched using various terms on google but most have been post's from a few years ago.
    I ran the download through Mediainfo and it's the same copy that i've been stuck at 98% on qbittorrent for ages. So a double thank you.
  6. "User Agent Switcher" for Chrome or Firefox.
    Choose "Android mobile device" and you will see the m3u8 link
  7. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You could try this method. I'm curious to see if it works https://forum.videohelp.com/threads/408582-How-to-download-video-from-embedded-link#post2721544
  8. Cedric, is it this version??
    https://chromewebstore.google.com/detail/user-agent-switcher/meolldikblbfbekojppimgfjd...e=ext_app_menu
    "Android mobile device" not available in this version.
    only says kitkat,.... and i really wished it did work
