I have a VHS of a 30 year old dance performance, about 7 minutes long, and the colors are way off. Everything appears redish hues. Interestingly, I have a photograph from that performance which has all the correct colors. I'm working with a lagarith capture and processing in avisynth+. Can any of you point me in the right direction if there's a function that may work?
Since the performance is the same lighting, costumes and backdrop throughout, it seems like I should be able to match it. I'm looking at colourLike(), but it seems like it wants an input clip to generate a histogram. Is there a way to perhaps get it to read a .jpg?
You can use ImageSource to create a video from a jpg .
There is also MatchHistogram , TweakHist (from manyPlus), GamMatch, RGBAdapt
But if there are too many changes compared to the single image, none of those will work very well - you're probably better off manually correcting it in something like Davinci Resolve
Event based panel help
By membervip39 in forum Video Streaming DownloadingReplies: 0Last Post: 18th Dec 2023, 11:48 -
Aren't Subtitles Based on Time?
By Spiffy577 in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2023, 09:06 -
Search for files based on properties?
By djomega971 in forum DVD RippingReplies: 1Last Post: 26th Mar 2020, 20:00 -
put a white border around a photograph
By David Banner in forum Newbie / General discussionsReplies: 6Last Post: 3rd Mar 2020, 23:37 -
Decent USB-based audio capture device for PC?
By Cyber Akuma in forum Media Center PC / MediaCentersReplies: 8Last Post: 8th Mar 2019, 09:07
