WHen i play my verbatim cd-rw i get a messege on my dvd player saying C 13:00 and it keeps flashing and won't stop. i can't do anything and the movie won't play... anyone know how i can get around that??????
thanks
Results 1 to 9 of 9
I have the same problem and was unable to find any info after a message search.
Brand new Sony DVP-NC600, Plextor PleXWriter 24/10/40A and Easy CD Creator 5.0. I've tired 3 different brands of CD-R's and they all give the "C:13" messsgae that the disk is dirty, when trying to play.
I tried a CD-RW, but Easy CD says it can only burn it as a Audio CD, does it need to be formated first?
Anyone found a fix for this problem with Sony's?
Can someone recommned a different brand of a 5 disk changer player that isn't a flaky as Sony?
Thanks in advance. -
thanks for the heads up dude, i have also been talking to other people about this, they told me to put in the DVD Hack, which i did and still doesn;t work.. btw i have a DVP-S560P dvd player... i am going to buy sony cd-rw disks soon, and get back to you on if they work or not... hopefully since they are sony disks they will be compatible with the sony dvd players.....more to post
thanks -
I did some testing last night and was able to get CD-R and CR-RW (had to use Nero for the CD-RW) to work when burned at 4X. The CD-R's that were unsucessful were burned at 24X. I'm going to burn a few more at increasing speeds to find a max burn speed.
i bought verbatim cd-rw and burned them wiht easy cd 5 at 4x and it just said C 13:00 on my dvd player...u know what that is all about???
i put the hack for my dvd player in and still had no luck with it, have u tried sony cd-rw cd's yet, and if so can u tell me how u burned them
converting bad laser Sony DVD players into Test Pattern Signal Generators?
By turnkit in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Jan 2012, 03:46 -
Editing DVD Titles for display on a Sony 400disc DVD Players menu
By drewp in forum Authoring (DVD)Replies: 5Last Post: 3rd Apr 2009, 08:25 -
Cant seek my encoded divx avi's with HW players ... plz help
By samykoka in forum Video ConversionReplies: 2Last Post: 17th Mar 2009, 14:19 -
Authoring so that my standalone DVD player can respond to remote control
By cprelude in forum Authoring (DVD)Replies: 3Last Post: 22nd May 2008, 13:03 -
Sony DVP S360 DVD players - No DISC ERROR
By parmar in forum DVD & Blu-ray PlayersReplies: 16Last Post: 14th Dec 2007, 10:44
