1. I ripped a commercial, pre-recorded DVD (6.63 GB) with AnyDVD. It went fine. No problem at all, as usual.
2. For the copy, the blank disc I only use is Verbatim. This one is DVD+R DL (8.5 GB, 8 X).
3. I tried several times with two different software: Nero and 1 Click DVD Copy. Neither one ever gave me a problem before.
4. I tried with three different burners: Pioneer (portable), the new Matshita BD-MLT UJ240ES (portable) and GU90N (internal).
5. Yesterday, the burning process failed four times, each time with a new blank DVD at 4x speed. The error message was:
“Could not perform end of Disc-at-once
Burn process failed at 4x (5,540 KB/s)”.
6. Today, it was a different story. Doing the same thing I did yesterday, I finally made a copy although Nero gave me 16 “Read error” messages.
7. Nevertheless, the copy plays perfectly fine either on my PC or my standalone player connected to the TV set after losing so much time and effort.
If I got similar responses with 3 different burners and 2 different software for burning, using 4 different blank discs,
what or where is the problem?
My OS is Windows 11
Attached please find the log for the last try.
Did you rip to ISO or video_ts folder?
Read errors during the verification stage would mean the program is not able to get a good compare of the sectors on the
optical disk and the source files on the HDD/SSDLast edited by davexnet; 19th Feb 2024 at 16:53.
I ripped te original CD to ISO against all warnings from AnyDVD. Then I burned the ISO with ImgBun against the long, explicit warning from ImgBurn. Well, I got a perfect copy, using one of the two blanc discs that we considered as a possibility that it was at fault.
This is a new learning for me and a new alternative way to burn CDs. -
Subtitle Edit appears broken...fix OCR errors creates errors on or off??
By Ronstang in forum SubtitleReplies: 9Last Post: 12th Dec 2023, 22:13 -
Error mesages: "Reading errors from sector.... to ......"
By Marcial in forum Authoring (Blu-ray)Replies: 12Last Post: 2nd Dec 2023, 01:46 -
Movie Edit Pro 2016 Blu-Ray Burning Errors
By Steelerfan43240 in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Jun 2021, 17:12 -
Avysinth plugins ClipBlend, ClipClop error: unexpected character ""
By CoralMan in forum EditingReplies: 2Last Post: 23rd Nov 2020, 16:26 -
BDInfo Not Reading Everything
By LeopoldBloom in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2019, 12:06
