Hello, I'm completing my hardware stack for VHS capture.
VCR has SCART outputs (I believe both are full 21 pin), GV-USB2 is on its way and it has s-video.
Can anyone recommend quality SCART->s-video (SCART male->s-video male) cable on-line? Even the respected brand name would be good advice.
Like this? https://www.ebay.it/itm/335127985225
Preferably shortest possible as I would rather extend the digitalized USB connection than transmit analog over longer cables.
Thanks.
bonus question, does s-video carries audio?
Maybe I would rather have SCART breakout adapter (SCART male to chinch L+R, s-video female and composite chinch) https://www.av-connection.com/?PGr=139
plus
s-video male->s-video-male https://www.av-connection.com/?PGr=130
https://www.av-connection.com/?ML=293
Results 1 to 9 of 9
First of all, are you sure that your VCR can output Y/C? Devices doing that generally also have S-Video connector. What's your VCR?
Golden ones not necessary but get one that has good shielding (so bigger than usual), same principle for single A/V cables and obviously 75 ohms certified
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Unknown model to me. Are you sure it can output Y/C (I suspect not)?
That's a regular VHS VCR, S-Video is not relevant here, Just get a SCART cable with yellow, red and white RCA connectors on one end.
Yes. Look for something like this:
[Attachment 77141 - Click to enlarge]
You may then use a recommended DVD recorder (Panasonic) in passthrough to 'convert' the yellow Composite video to S-video. It would help to stabilize the picture (wobbling, flagging ...) and reduce the typical composite artifacts (dotcrawl, rainbows).
First try with the GV USB 2 composite alone as it provides an acceptable Y/C filtering.Last edited by Sharc; 20th Feb 2024 at 05:41.
Appreciate your help on this, crap, I thought that this VCR is worth something (4 read heads, 2 write heads). Need to re-think another device. Still will see if Composite produces any useful result.
All VCRs have only 2 heads for playing and recording, Some have extra two heads for low speed, but only two heads at a time are used for normal playback or recording, 4 head is a marketing gimmick.
The best way to test a SCART-SCART cable (?)
By rgr in forum Capturing and VCRReplies: 1Last Post: 11th Dec 2023, 14:25 -
HDMI to S-Video cable or SCART to S-Video cable.Which is better for elgato?
By VideoFanatic in forum Capturing and VCRReplies: 22Last Post: 23rd Jan 2023, 14:40 -
Panasonic S-VHS NV-FS200 no signal video from scart
By Nicola71 in forum RestorationReplies: 15Last Post: 5th May 2021, 19:09 -
Capturing Scart with VHS/DVD combo player
By SJ-M- in forum Capturing and VCRReplies: 29Last Post: 19th Feb 2020, 12:40 -
difference between using a s-vhs scart socket contra a s-vhs s-video jack
By Desve in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2019, 11:59
