Hi everyone, I know this topic has been discussed many times but how its done always seems to be a little different.
What is the best format to save my old tapes at? I have been using AVI/ DV-AVI which I thought was basically the same, but recently I have seen other formats being suggested. My goal is to save with the lowest video quality lost as possible. Size isn't an issue. Recently I have been converting a few TC-30 tapes, so my process to do this is I put the TC-30 tape into a VHS-C adaptor and use a VCR to play the tape, then I have my VCR hooked to a Sony 8mm camcorder with the "pass-through" feature. Then I have the camcorder connected to my computer by way of the 1394 dv fireport. I have been using Adobe Premiere Pro to save the video files to my computer. Capture formats that are offered are DV or HDV. I always thought this was the best way to save my old video files without any lost of video quality. Am I correct in thinking this?
Thanks for the help.
Results 1 to 1 of 1
Problems transferring video footage to PC from DV
By Ginger-Overlord in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 9th Aug 2023, 13:41 -
Tape ruined camcorder. Camcorder ruined tapes. Tapes only play static.
By camcorder problem in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd Jul 2023, 06:06 -
no audio when capturing 8mm tapes to computer. Camcorder has a mono jack
By smoneydrains in forum Capturing and VCRReplies: 1Last Post: 21st Sep 2020, 16:47 -
Transferring 8mm cassette footage to my computer?
By maxton in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th Mar 2020, 13:12 -
Lost frames/packets when transferring HDV footage from MiniDV via Firewire
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 4th Mar 2019, 02:55
