There are no instructions anywhere. How to save A-B Repeat List timestamps?
.PBF file is not created automatically with appropriate setting (Playback > A-B Repeat > Remember A-B Repeat List)
I manually created a .pbf file with same name as video file, I don't know what I did but I got it to save once but the times were off, now nothing I try works
All I know is the header is [PlayRepeat]
EDIT: It looks like it saves only after you close the video
I don't think A-B repeat list can be saved.
BUT if you have (I use an external) .PBF file where you have bookmarks at start and end of some part, you can view all parts of video in playlist AS a separate files /it is temporary/, then you can repeat part you want.
It is here, context menu:
Playback -> Chapter/Bookmark [H] -> Play bookmarks as separate files in playlist
(Note: create some bookmarks first of course) -
You can also view bookmarks as separate files in File List and make a repeat of one (similar to A-B repeat list?) or more.
Repeat every 5th frame
By pooksahib in forum Video ConversionReplies: 4Last Post: 12th Mar 2023, 08:00 -
Potplayer- How do you save multiple playlists all at once?
By tra in forum Software PlayingReplies: 4Last Post: 15th Mar 2021, 16:58 -
Get a list of Youtube video titles from a list of URLs
By abolibibelot in forum Video Streaming DownloadingReplies: 3Last Post: 12th Oct 2020, 04:42 -
Potplayer Bookmark Editor: Can't I Save .pbf Files?
By Michael Linder in forum Software PlayingReplies: 1Last Post: 26th Aug 2020, 18:55 -
VirtualDub -- “SAVE”, “SAVE AS”, “EXPORTING”, re-encoding
By Avagadro1 in forum EditingReplies: 2Last Post: 13th Aug 2020, 11:44
