  1. https://www.syfy.com/resident-alien/season-3/episode-1/lone-wolf
    Can only see .ts in the network cache doesnt look like its encrypted how can you grab this for example please
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    N_m3u8DL-RE.exe https://link.theplatform.com/s/HNK2IC/media/guid/2304990266/9000267957/stream.m3u8?manifest=m3u&switch=HLSServiceSecure&formats=mpeg4
    Needs a US proxy or VPN.
    Edit: Seems I was partially wrong. You do need a US IP, but just for access. If you edit the downloaded master m3u8 file, you can get around the geo detection and not waste data on the downloading. You would only waste data by accessing the bare minimum stream information.
    master_hls.txt
    Download and change format from .txt to .m3u8 and run:
    N_m3u8DL-RE.exe master_hls.m3u8
    Or you can download it from: https://www.transfernow.net/dl/20240215VGVmAgO6
  3. Thanks ill have a look at how to find the correct stream header in the browser from your example thanks for your assistance. just learning
