I want to remotely obtain an m3u8 from this API (it has geoblocking outside of Spain).
https://api.atresplayer.com/player/v1/live/5a6a165a7ed1a834493ebf6a
I have managed to obtain it with PHP and Python (it gives an error from JavaScript). The problem is that the m3u8 is only valid for the server's IP, not the client's, so the solution with PHP is not valid. But with Python, I don't know how to access it from Google Chrome. I have tried to make the JS call to Python but I haven't been able to.
Any ideas?
Results 1 to 14 of 14
So the server is in Spain and has no geoblocking problems, but the client isn't?
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
The m3u8 contains a token that only works on one IP. Something like this: https://atres-live.atresmedia.com/6b550f7bab68261fdc56353d5f2588630c376881_ES_17079340...a3/master.m3u8
What I want is for it to work on the client's IP.
If I use PHP, the m3u8 only works with the server's IP.
With JavaScript, I can't access the API, it throws an error.
With Python, I can obtain the m3u8, but I don't know how to access it from the browser. -
Even if you get the m3u8 link from python, it's still tied to the server IP. What's the JS code and what's the error? Are you using a proxy? Another alternative that you could try, you could offer a endpoint server side that gets the m3u8 link from them, but doesn't return it. Instead it returns the content of that m3u8 link by using another get request on that token bound m3u8 link using the same IP it got bound to (the server). Basically acting as a middle man.
I'm getting a 403 error with JS (the server is at my home in Spain). However, with PHP, it does allow obtaining the m3u8.
JS
<script>
fetch('https://api.atresplayer.com/player/v1/live/5a6a165a7ed1a834493ebf6a')
.then(response => response.json())
.then(data => {
const url = data.sourcesLive[0].src;
</script>
PHP
<?php
$url = json_decode(file_get_contents('https://api.atresplayer.com/player/v1/live/5a6a165a7ed1a834493ebf6a'), true);
$url = $url['sourcesLive'][0]['src'];
echo $url;
How does the "endpoint server" work? -
Well of course the php works since it is server side and the javascript doesn't since it's client side. You could research the idea of using fetch with proxies. Before I try and explain my idea, let's consider that you get the m3u8 link and you can do stuff with it client side. What is it you wanna do? Do you just want to play a stream client side or is there any other objective?
I just want to play a stream client side using JW Player. Being able to use it from the mobile using data, etc.
What is your idea? Nice avatar, by the way. -
First check if the contents of that m3u8 are geoblocked as well. Download a m3u8 on your server from spain and paste its contents here. How does the m3u8 look like? You should check if a random fragment from that m3u8 is geoblocked as well. Can the fragment be accessed client side?
Do something like (this is pseudocode so don't copy-paste)
Code:response = requests.get("https://api.atresplayer.com/player/v1/live/5a6a165a7ed1a834493ebf6a").text m3u8_url = parse_json(response) response = requests.get(m3u8_url) print(response)
The m3u8 is geoblocked too: https://atres-live.atresmedia.com/6b550f7bab68261fdc56353d5f2588630c376881_ES_17079340...a3/master.m3u8
"6b550f7bab68261fdc56353d5f2588630c376881" is the token, valid for only 1 IP.
I've already have a Python script to extract the m3u8. The problem is that it's also not for the client side. -
I know that. You made yourself clear up until now. What I am interested in is the content of that m3u8. A sample m3u8 would look like this:
Code:#EXTM3U #EXT-X-VERSION:3 #EXT-X-TARGETDURATION:10 #EXT-X-MEDIA-SEQUENCE:0 #EXTINF:10.000000, fragment_0.ts #EXTINF:10.000000, fragment_1.ts #EXTINF:10.000000, fragment_2.ts #EXTINF:10.000000, fragment_3.ts #EXTINF:10.000000, fragment_4.ts #EXTINF:10.000000, fragment_5.ts #EXTINF:10.000000, fragment_6.ts #EXTINF:10.000000, fragment_7.ts #EXT-X-ENDLIST
I'm not sure if the .ts are geo-blocked. I can download them using VPN: https://atres-live.atresmedia.com/6b550f7bab68261fdc56353d5f2588630c376881_ES_17079340...1-170794477.ts
Perhaps I could generate an m3u8 with those .ts files or something like that. Was that your idea? In that case, I suppose I could do something with PHP.
Edit: I've created an m3u8 with .ts files, and it only works locally. In fact, they contain the same token.Last edited by Babuino; 14th Feb 2024 at 15:36.
My original idea was designed for worst case when the fragment ts were geoblocked as well with that token of yours. It basically turns your spain server into a proxy. Consider this. Whenever a m3u8 is played on a page it does a series of GET requests. GET .m3u8 file. GET first fragment, GET second fragment and so on and on.
If you were to design a server api that has no problem with geoblocking you could do it like this. (python + flask for showcase, you can write it in whatever you are used to)
Code:import requests from flask import Flask, request app = Flask(__name__) # this acts as a proxy to get the main m3u8 @app.route('/get_m3u8', methods=['GET']) def get_m3u8(): response = requests.get("https://api.atresplayer.com/player/v1/live/5a6a165a7ed1a834493ebf6a") # or whatever link you have m3u8_url = m3u8_parse(response) m3u8_content = requests.get(m3u8_url) m3u8_content = m3u8_modify(m3u8_content) return m3u8_content def m3u8_parse(response_json): # here you extract your m3u8 from that json # example: https://atres-live.atresmedia.com/6b550f7bab68261fdc56353d5f2588630c376881_ES_1707934082_1707962822/h264leg/live/antena3/master.m3u8 pass def m3u8_modify(m3u8_content): # if each fragment was geoblocked, you make a URL that points to the second endpoint of your flask API # example: your_python_server/get_fragment/fragment_1.ts # this endpoint will obtain the content of that ts fragment because it is not geoblocked here # for each fragment do this URL modification pass # this acts as a proxy to get the content of each fragment @app.route('/get_fragment/<path:fragment>', methods=['GET']) def get_fragment(fragment): base_url = request.args.get('base_url') fragment_url = f"{base_url}/{fragment}" fragment_content = requests.get(fragment_url) return fragment_content if __name__ == '__main__': app.run()
ChatGPT also suggested me to use Python + Flask
Thank you very much for your help, I'll take a look at your code.
Help obtaining keys
By DenialOfJustice in forum Video Streaming DownloadingReplies: 8Last Post: 28th Jan 2025, 01:34 -
Help Accessing HIDDEN 1080p M3U8 File
By save8lot in forum Video Streaming DownloadingReplies: 53Last Post: 21st Feb 2024, 07:57 -
Which editors have an API?
By apiman in forum ProgrammingReplies: 7Last Post: 1st Dec 2023, 11:31 -
Accessing api
By Sadomasochist in forum Video Streaming DownloadingReplies: 0Last Post: 12th Feb 2023, 10:59 -
api request
By birbal1 in forum Video Streaming DownloadingReplies: 5Last Post: 15th Apr 2022, 13:47
