  1. I downloaded Star Wars 2 off of Kazaa (SMR) and when I'm trying to extract the audio in Virtual Dub I get the error "No Input Audio Stream to Extract". I have it set for full processing mode, selected the conversion and compression.
    Any suggestions?
    Dec 2001
    USA
    It might be a bogus file? can you play it on PC?
    In Vdub click on file> open video file> select file> open> file> File information. You will see what codec it's done in and what the audio is.
    May the force be with you.
  3. here is the info
    Frame size 352x144
    # of frames 21773
    Decompressor Uncompressed RGB1
    number of key frames 21773
    etc etc etc
    I tried opening it up and none of my players would open it.
    There is no info in the audio section!
