  1. i downloaded a game from a file sharing site. it came in two seprate files. they were both about 645mb. after downloading them i burned them using nero in iso format. using winiso i tried to open them but couldn't. is there a way to use downloaded software such as games? for reference this game was dungeon seige. Any help would be appreciated
  2. yes you can download games, programs, movies, you can download anything that is digital, or that can be converted digitally. You have to give more information in order for someone to help. The kind of file you ended up with, was it a bin and a cue, or was it a iso, need more info here
  3. Was the file you downloaded a self extracting file.
    Coz if it was then it's probably just a simple case of extracting it to a directory and running it with the .exe icon within the folder.
    Extract the second file to the same parent folder.
