    May 2005
    Australia-PAL Land
    I have a friend, less skilled than me , who is working on a video which was captured a long time ago (tape no longer available). He/we want to remove the magenta halo along the left edges of the white(ish) objects such as the sleeves. I've had a go with Chromashift moving CR to the left 7 pixels which wasn't bad (still a bit smudgy, and the red chest badge ended up with a red splodge on it's left) but I'm wondering if there are any better solutions, VDub, AVISynth or otherwise, to clean this edging halo.
    As you can see, the sections with the bright white light are mostly affected so I assume the same code could be applied to each bright section. I'll do the legwork in that regard.
    I've attached a snip of it as an MP4 as that is the format I received it and I thought you'll be able to see more of the video. The whole file is ~650MB
    Any thoughts or suggestions from the floor would be very much appreciated.
    canada
    If you look at the video closer there's also haloing along the left,right and top borders,i would leave it alone.
  3. This helps a little:
    LWLibavVideoSource("Concert Snip.mp4")
    ConvertToYV24()
    Tweak(sat=3.0)
    u = UtoY().aWarpSharp2(depth=10)
    v = VtoY().aWarpSharp2(depth=10)
    # shift u and v differently
    u = Overlay(u, u, x=3, y=0)
    v = Overlay(v, v, x=-9, y=-3)
    # recombine u and v with the original y
    YtoUV(u, v, last)
    I think there's something else wrong too. Maybe leakage of luma into the chroma. No time to analyze now.
    May 2005
    Australia-PAL Land
    Does anybody have any tips for minimising the black comets along the microphone stand? I tried with Neat Video but wasn't completely successful.
    Sorry, thanks for that. The Chromashift filter from JPSDR works well for moving the red/pink/magenta edge on the first attachment so I'll stick with that. It would be good to lower the overall red smudge though eg on this attachment's man's shirt.
