Hello,
I am hoping someone can give me some advice to solve this issue!
I have a Song HVR-V1U camera that I have had no issues with transferring footage from using to Firewire to Thunderbolt 2 to Thunderbolt 3 method. Today I took some footage and went to go capture it on my laptop... I ran into some issues, was finally able to see that the computer is recognizing the input... but HDVSplit will NOT detect my camera. I opened WinDV just to check and... it's working on there. Which makes NO SENSE because I am trying to transfer HDV footage.
Does anyone have ANY idea of what I can do? I already tried re-downloading and it doesn't work. Does anyone have any idea of a different software I might be able to use?
Thanks!
Results 1 to 11 of 11
I'm not familiar with the V1U but my HV20 shows what tape format is being played in the monitor; it will say DV or HDV. It will obviously have to say "HDV" for HDVSplit to function. Could the tape being played be a tape recorded in DV mode?
My WinDV died some time ago but Scenalyzer will "see" my HV20 even when it is in HDV mode: it's shown as "Canon HV20". Of course, it won't actually transfer.. When my HV20 is in DV mode, it show up in Scenalyzer as "Microsoft Camera/VCR" and it will transfer. Exactly what is shown in WinDV might provide a clue. -
Hello,
when I say 'working' I mean that I was actually able to transfer video (but very low quality) when I tried using WinDV. I just checked the camera and it says 1080i on the playback screen so it's definitely HDV. I also recorded it on HDV tapes.
Edit: Just opened Scenalyzer Live and it's showing up as 'Microsoft Camera/VCR'... this is very strange. -
This is a camcorder setting, try automatic or set to HDV output manually.
I solved the problem! It was a camera settings issue!!
The solution: make sure the i.LINK conversion setting is put to 'Off'. For some reason mine was on and that was the problem! -
Weird. In my experience, the DV transfer programs (WinDV, Scenalyzer) will just not transfer if the camera is in HDV mode or the tape recording is HDV.
I'm interested to know if Dellsam's suggestion works.
I also recorded it on HDV tapes. -
My suggestion was what he did exactly, disable DV out or set it to automatic so it will switch to either DV or HDV based on the tape content, but the auto mode could be problematic if tapes have mixed recordings.
HDV labeled tapes made back then were slightly better for both DV and HDV recordings, I tested them back in early 2000's with my then the Sony FX1 and later a Sony consumer one and the regular tapes exhibited occasional drop outs but the HDV premium ones had no dropouts, Did I buy them at premium price of $35 a tape? no, Did I use a lot of them? no.
HDV Split software
By Tonyd520 in forum Newbie / General discussionsReplies: 13Last Post: 21st Jan 2024, 06:50 -
TBC advice for HDV tapes + HDV tape deck?
By dterranova in forum Capturing and VCRReplies: 34Last Post: 3rd Feb 2023, 23:22 -
Capturing SD footage from HDV Cassettes
By Kong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 6th Oct 2020, 22:20 -
Grabbing mini-DV footage in Windows 10 (Using WinDV and HDV Split)
By Kong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 21st Sep 2020, 20:08 -
WinDV and HDV are no longer 'seeing' my Vixia HV30
By Kong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 17th Jun 2020, 23:16
