Let's just say I have 15,000 images. How do I select the first 7,000 images in File Explorer, XnViewMP, or some other program without having to manually select then or by dragging?
Click onto a file you want to start selection with, the scroll down to see the file you want to end a selection with and click on that file WHILE pressing "Shift" as well.
If you want to exclude a file from that selection. Click on that file within selection WHILE pressing "Ctrl"
This is a standard way to select or unselect files. -
Do not attempt to upload somewhere 15.000 images though.
It must be zipped in something. You see right here what nonsense it is. You rather upload original, cut, mp4, mkv, m2ts. The other party can easily download zip with original video cut(much smaller file) and gets PNG image really easy from any videoplayer etc. You upload file to one of those dedicated storage servers.
I can't select the added audio
By Lucho in forum Authoring (DVD)Replies: 5Last Post: 7th Jul 2023, 12:05 -
MultiAVCHD Title Select Screen
By citycentrefox in forum Authoring (Blu-ray)Replies: 3Last Post: 4th Oct 2021, 14:38 -
Small amount of blank space added to audio when converting with Handbreak
By Rowsinator in forum Newbie / General discussionsReplies: 9Last Post: 15th Sep 2021, 00:25 -
How does one select an appropriate bitrate?
By GoodEnough in forum Newbie / General discussionsReplies: 12Last Post: 24th Aug 2021, 15:21 -
Can't re-render video without it outputting the wrong amount of frames
By Rathma in forum Newbie / General discussionsReplies: 6Last Post: 9th May 2021, 21:46
